Did a search and came up EMPTY in this category which surprised me actually.
I have the Hypertune V2 manifold which has 12 bosses for fuel injectors and I'm thinking of using the other 6 (currently not drilled through) injector ports for water injection nozzles. I have seen where water/methanol injection consistently beats 116 octane fuel when used on top of 93 octane and I'm thinking this may be perfect for my streetcar. Does anyone here have any experience with this setup?
I am at the limit of 93 octane at about 20 psi boost on my 850cc injectors currently and have a pretty good fuel pump for it (AEM 380 LPH pump) so I'd like to keep from changing over to an E85 system for now (which would require another fuel pump, bigger injectors (1300cc), lowered fuel mileage, etc). The Haltech has extra PWM ouptus and I have a couple of digital relays here, so I'm thinking of installing a water/methanol system which will be controlled VIA Haltech.
I'm not sure what it does to the wideband reading, and I'd like to see if anyone has a "go-by" of sorts for setup (nozzle sizes, AFR targets, etc).
EDIT- I think I have calculated for 25 psi boost and 50/50 mix of water/methanol I would need about 800-1,000 mL/min of total injection rate. I'd likely start with 30% duty cycle and ramp this up with my power levels from 15 psi up (probably some ratio of fuel injector rate) up to 25 psi. So I'm planning on using (6x) 1.9 GPH nozzles and building a kit. I'll likely get the snow box to ensure flow during running as well (assuming this can be read by the Haltech).
https://www.sau.com.au/forums/topic/465743-methanol-water-injection/
I have the SPIII kit on my Gts25t but its a single point injection..........so I'm not even close to what you are doing.  And there is plenty on here about WMI, but in all the discussions Mafia or I and others have started, I can't remember anyone on SAU talking about 6 injection points or the setup you are looking at.
Search wmi or meth perhaps.
Pretty sure the thread n it was discussed as recently as last month so maybe just scroll down a few pages of topics even.
Would there be any issues doing it multi port, or benefits over single port?
This topic has actually had fairly extensive coverage on these very forums and there are a few threads that are actually quite recent.
You will NOT want to inject at the runners.  You want the water to go in as early as you can to give it some time to evaporate.  So into plenum or intercooler pipe is generally considered to be better.
Do as instructed above.  Search some more.  Don't use the forum's own search function - they are usually as weak as piss.  Use google and point google to just sau.com.au.
You still need more fuel.. so if you're at your so called limits then you'll need to upgrade your fuel system.
As you inject water/meth your mixtures will lean out, thus requiring you to ram in more fuel. Basic rule, tune for under 11:1 AFR for Gasoline, and inject water/meth to you bring your mixtures back to high 11s. Then start advancing timing... in your case you don't need to advance timing as you're already running so much for Gasoline I'm suspecting you're nosing over MBT for that rpm vs. load.
Benefits of multiport are the same as same for nitrous. Ensuring the same amount of protection goes to all cylinders. I would also add a 7th larger nozzle post-intercooler to reduce overall temp as well
Actually I'm reading the opposite of this from the manufacturers.
I'm running 6x 850cc Bosch EV14 injectors. They run very well. Seeing about 85% duty at 8k rpms and 18 psi boost. Also I'm at 19.9 deg of timing and no knock up there. I'm at about 24 deg timing at 7k rpms and it slowly dives down from there to the almost 20 deg.
1) a single injector in the post-intercooler stream will reduce intake temperatures which can help REDUCE power LOSS from heatsoak, but only makes more power IF: the AFR is adjusted on engine, the boost is raised, or the timing is bumped. If none of these are changed the engine will be likely more reliable, yet make less power.
2) They are saying that meth/water injection makes the mixture richer and reduces power initially if no other changes are made. Makes sense because methanol is a fuel after all and water is reducing the combustion temps in the cylinder which effectively should be robbing some amount of heat energy that normally turns into POWER. That being said, I think the additional ACTUAL octane of the methanol is marginal and is not what is making then engine safer to run higher boost and more advanced ignition timing...
Using the SNOW performance table here where I'm at currently (18 psi boost about 600 HP) they suggest a 624 cc/min (or mL/min same units) of injection rate. This means that really I could use an extra fuel injector (IF they atomized as well as water injection nozzles - which they don't) to inject the water/meth. Given a 50/50 mix the additional fuel is still around 310cc/min of extra raw methanol. Granted, methanol is supposed to run SIGNIFICANTLY RICHER than Gasoline so this amount of actual added octane due to the additional methanol is negligible IMO.
The benefit of a single fogger nozzle is that it cools the intake charge and having this upstream of my IAT sensor (which is smack in the middle of my manifold) would allow me to compensate for the decreased IATs.
The benefit of the multiple nozzles would be the ensure that I am getting the same amount of actual fluid injected to each cylinder as opposed to relying on the single fogger to distribute to all cylinders equally. I would say that this is the real purpose of the methanol as it would evaporate significantly quicker into the airstream and keep the vapor more evenly distributed in the air stream through the runners.
My goals would be to:
1) Leave the low end power level where it is at about 16 psi or so. Perhaps only inject on top end or at boost onset to keep the max torque from causing detonation. Stretch my boost out to 20 psi and see what it can do with WMI and more timing. Since the injectors could be leaned out (and I'm currently at 85% at 8k rpms at 18 psi) I think the meth/water will allow me to stretch these 850cc's out a bit more and the timing advance is simply easy free'd up horsepower at this point. This will max out my 850cc injectors I'm sure. Then once I get comfortable with this...
2) Change fuel injectors to 1,000cc see if I could support 24-25 psi reliably on the water injection and 93 pumpgas. I doubt I would want more than this amount of horsepower at that point because I would be worried the trans would totally grenade.
this is where I face palm myself :(
water/meth will richen up mixtures, as you're injecting a combustible.. I have no idea why I said it would lean out mixtures.. probably all the ethanol use has fogged my mind haha
  • Like 1
With the SPIII kit you can set the unit to idc and psi.  Plus you can start at say 14psi and have it all in by 18psi, and at the same time 60% idc and all in by 75% say.
I wouldn't leave it just for the top end, I would start my ramp up earlier and have the benefits already happening but ramping to max as you and where you need it most.  So I wouldn't just be thinking top end.
Its been a while [cos it just works], but I think mine is set to 8 and 14 psi and 40 and 75 idc.
  • Like 1
  I can build the whole table in the Haltech as well and just have it run the injector solenoid on PWM. I'd like to see how to wire in their little fail-safe flowmeter though as I'm out of 5v inputs. I may just run one of their kits with a couple of nozzles to get to 20 psi and try the individuals later when I want to run more with more fuel.
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
