Hi guys,
Thought I would keep a log of the current build with Josh at Galvsport.
Some of you may have seen it recently.
f1WyhdPyMfBGed7V4vEV1jp5hRtS9RcqQ9fpqd_6
Basic Build Spec:
RIPS RB32 with the entire kitchen sink.
Brad Stacey Cage
Full Restoration with brand new exterior Rubbers/Trims
Genuine Veilside EIII
Billet Merge Collector
GW3884R (AKA6465) street Setup.
CPC Billet Plenum.
102mm DBW Throttle body.
Full Set of Nismo Links
MCA Reds Nitto II spec.
Quaife Diffs
The DriveShaft Shop Axels and DriveShaft.
https://www.sau.com.au/forums/topic/465922-rb32/
6 hours ago, JH32 said:
NIce specs, what's some of the history behind the build?
This is actually my second GTR after bending the chassis on the first one back in 2011.  It was literally in the last stages of being built to how I wanted at the time (only a brakes  upgrade remaining because they'd sent me the wrong parts). It then sat in storage waiting to be re-shelled, kind of pissed me off every time I thought of it so nothing happened for a couple of years.
Then I bought a shell in 2013 but as I was doing long stints of FIFO at the time, not much happened so I sold the shell in 2015 and was going to part out the first car.
Not long after that, my dad had to have a emergency quadruple bypass recently which put things into perspective. I didn't like how I'd never finished building a GTR so I went and bought another GTR that needs some work and here we are. The first car will serve as a donor car  to the current project although the spec has changed quite a bit since then.
Hopefully everything goes well with this build and I can enjoy it until I am physically no longer able to do so.
  • Like 1
https://www.sau.com.au/forums/topic/465922-rb32/#findComment-7760036
  • 5 weeks later...
  • 9 months later...
    • I know -_- Oddly enough I went to a car show this weekend and not a single person made any mention of Nitrous... I did have to argue with a know it all that was convinced I had an RB26 head with HKS V-Cam as opposed to a regular VCT RB25 head, but what do I know. I think my HKS oil cap was throwing him off.
    • That seems like a lot more work than just using a second jack under a front tow hook to raise it enough to get another jack under it.
    • They're wonderful when only used to lift your car up an inch so a real jack fits under your front lip. Besides that, I've only ever used them on the side of the road.  We call them widow makers here.  Unfortunately, like I mentioned in another post, ramps are not an option for me due to generally working on my car once my kids are asleep. Cold starts, 4" exhaust and sleep rarely go well together. I honestly find using ramps a hell of a lot more work than what I'm currently doing anyways.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
