I picked up my new to me r33 gtr the other day and have put about 200km on it so far. It has a remote oil filter setup with a fairly larger oil cooler hooked in with it. I dont see any sort of oil thermostat valve and its takes a good 25 minutes before the oil temp gauge even shows the needle at the lowest 70*C mark and never goes over about 75*C while driving, cruising at 100km/h it drops below the 70 mark. What would be the recommended thermostat temperate to get. I found one that will fit with my setup that came in 86*C or 102*C options, was thinking the 86*C would be the safe bet?
Edited by Josh222
https://www.sau.com.au/forums/topic/465980-oil-temp-issue/
Just make sure the sensor unit isn't faulty.
Water temp sensors, Oil Temp sensors and Oil Pressure sensors ALL PLAY UP!
I had EXACTLY the same thing happen with one of my R32's.
Swapped out the sensor and it worked perfectly!
Cheers,
Bob.
https://www.sau.com.au/forums/topic/465980-oil-temp-issue/#findComment-7760781
You will definitely need a thermostat in a cooler climate unless it's track only car. Out of the two options the 86C sounds like the pick.
Something to keep in mind is that if you go with a thermostatic sandwich plate there is always some flow through the cooler, irrespective of thermostat rating. I spent a long time battling my Mocal one, even swapping the wax pellet, and it's still slow to warm up on cold days -> too much flow through the cooler. From what I understand the Greddy sandwich plate is a better design in this regard.
As a last resort, if your cooler is too eager even with a thermostat, what you can do is fab up a small plate to block the oil cooler during the colder seasons. That's what I've done.
Also others have said make sure you have a properly positioned, working temp gauge as the first step!
Some related reading:
https://www.sau.com.au/forums/topic/465980-oil-temp-issue/#findComment-7761164
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
