I have a r33gtst that is booked for a tune tomorrow.
I have all the supporting mods like r34 highflow, power fc etc.
My goal is about 240 atw
I bought a 1000cc topfeed xspurt injector kit from scottynm35 and even though i assumed they were too big, i was told that they are a much more modern design, can flow well at all power levels and therefore would be suitable for my application.
however the tuner tells me they are way too big and will not be suitable for my goals, he told me he can safely run the stock injectors by upping the fuel pressure with my aftermarket fuel reg.
What do you guys think?
Thanks
https://www.sau.com.au/forums/topic/466010-1000cc-injector-question/
Strictly speaking, they are too large.  You'll only need ~1ms pulse width to idle on petrol and you therefore have very little ability to tune the idle mixtures.  But it will work.  Idle may be slightly fluffy, or it could be perfect.
On E85 it would be easier.
But what you were told by others than your tuner is true.  They will work, and they will allow you to go E85 later very easily.
I shudder in horror at the thought of jacking up the fuel pressure to achieve 240 rwkW on factory injectors.
  • Like 1
Run the 1000ccs, technology has already advanced so far over the last 10 years, they'll be fine
Upping fuel pressure with stock injectors will only lift the headroom by so much over the 200rwkw, works fine but stresses your fuel pump and affects injector lag time anyway
My main concern is, will the car run perfectly on the 1000cc injectors? i dont want it to not idle well or run just "fine".
I will speak to the tuner later today about it, but its looking like i will just cancel and wait a bit longer.
it definitely did not seem right to just up the fuel pressure on the stock injectors. The thing is the tuner is very reputable among the skyline and silvia community and i have heard nothing but good things about him.
If your tuner is smart, and say in the event those milled X-Spurts (I don't have experience tuning them) don't idle well on 98RON, you can drop the fuel pressure to say 2.5bar with the vac hose off on idle (then connect it back once you've finished setting the FPR).
This means now you can run higher pulsewidths and have the correct amount of fuel injected to maintain the idle and AFR of your choosing and you have plenty of headroom for the future.
I've got 1000cc IDs....no issues on idle.  I'm pretty sure there about about 1,000 others on here who'll tell you the same.
Keep the IDs, get a new tuner.
1 hour ago, vxsr33 said:
Called up chequered tuning and they said it would be no problem, so going for a tune with them. :-)
i was told the new injectors dont have filters though. Does anyone know where i can get some? (Dont know much about injectors)
Very good plan :)
Trent is good, he will sort it out. Seen several maps most of which are very good.
Seen big tuning shops in Sydney with tunes that could be done by a 2 year old holding the number 8 key.
  • Like 2
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
