  • Replies 165
Hey - from memory you guys wanted to watch some Gwenith Paltrow movie or some such shite! At least rugby is a big step up from that crap! Still - we might have to do some flicking to the footy scores in the boring bits of the rugby (hang on - thats most of isn't it?)
Hang on nothing wrong with Mrs Roy (Paltrow) and nothing boring about Union, especially the dirty Sth Africans :P
Well its on people...its 5am Friday morning im at work and i dont have a car....so Hertz and an Echo and a prayer for rain might be the goer
But no matter what ill be coming...Remember if staying at the place i arranged we need to bring our own linen ...
As i walked to work with a full backback i wasnt able to throw in a dooner and a friend has my sleeping bag so if someone could bring a blanket for me, i wont need as big a beer blanket :P
Does supply own linen normally mean pillows/towels as well...i didnt ask (Sorry)
AND remember to bring your CAMS Licences :P ...
I saw your clutch being dropped off. Fingers crossed Troy! I'm still to pick up my car also.
Oh and I'm at work now and of course I forgot my linen too. I'll have to get the Mrs to bring it down with her.
LOL...nothing like leaving things to the last minute then panicking :P .
Well just got confirmation that the car is ready to run bar engine oil and power stering fluid, so onto the dyno for a tune and provided the thing can be tuned and runs ok then ll have a car...but im not getting my hopes up too high...the engine has warranty etc etc but the new engine is still an unknown quantity.
Heres to hoping for a change of luck, : :P
hope your car is ready troy, i wanna see the beast in action :P
my oil cooler is going on today yay
Oil cooler = peace of mind :P
...as for beast, if you mean loud, spews oil all over the track and akin to havign a growth on your ass, then yeh my car is a beast :confused:
And from the Bureau of Meteoroogy...strong winds but no showers and around 13-18degrees
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
