Hello,
Up for sale is my 1998 R34 GT-t. 133,111km. I bought this car a couple years back
and am the second owner. Vehicle was only driven on weekends.
Serviced every 5,000km
Vehicle drives well and makes good power. Last tune made 300rwkw and
is tuned by one of the best Microtech tuners around.
The fuel pump and reg are under 5,000km old. Basically new
Only reason for selling is I need a more family orientated vehicle
and don't have the time anymore.
Vehicle is manual
Greddy Intake Plenum
Greddy Type R BOV
Greddy Profec B-spec II boost controller
ID 1000cc injectors
Proflow 1L catchcan
Q45 throttlebody
Plazmaman fuel rail
Tomei Type L FPR
Koyorad radiator
Walbro 460lph e85 fuel pump
Fuel pump hard wire mod
Brae exhaust manifold
Splitfire coilpacks
Nitto clear timing cover
HKS GT3240 0.7 A/R
HKS Adjustable Cam gears
HKS Fine Tune T-belt
HKS 272 degree 8.7 Lift intake cam
HKS 264 degree 8.7 Lift exhaust cam
HKS Power Rocker Covers/ Valley Cover
HKS Oil Cap
HKS Special Racing Wastegate
Kakimoto exhaust tip
3 inch Mandrel bend straight exhaust
Hi-flow cat
Blitz SUS Power air filter
BC V1 Coilovers 8kg/mm front 6kg/mm rear
Work Emotion XD9 18x9+20 18x10+18
Relocated battery to boot
Exedy heavy duty clutch
Slotted/cross drilled rotors
EBC green brake pads (no brake dust!)
Microtech lt16c ecu + hand controller tuned by Anthony Rodriguez @ Maztech
Veilside gearknob
Contact Daniel 0466 577 808 prefer sms during work hours
$17000 ono
https://www.sau.com.au/forums/topic/466248-sold-fs-1998-r34-skyline-gt-t/
Hey mate, boot does look funny there. Had a look this morning. Looked ok. Will post up some more pics in better lighting. No existing damage on vehicle. Just a small dent lhr from previous owner. Paint wise theres chips around the guards possibly from previous owner rolling guards. But overall in decent nick. There is a slight knock from rhf castor bush but willing to fix it for right buyer. Sorry shouldve spent more time on ad. Any questions feel free to ask. Cheers
  • 1 month later...
    • Please use a modern ECU. PowerFC with the Nintendo Gameboy controller is horrible. It's not 2005 anymore.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
