9 hours ago, Piggaz said:
Opened up my filters two weeks ago after sitting around from November with E85 in the tank. These fuel filters were cleaned in July/August last year. This is what came out. Was pretty yuck.
Whole fuel system went in the bin!
AD372875-F66A-4E59-B5B3-A148391C7DB2_zps
Thats what I was talking about.
16 minutes ago, r32-25t said:
You bought it from uni group, they used Brad, fatz had exactly the same tank and is the only other person I've seen with this issue
I used Unigroup and they had the fabricator across the road make it.
i had no clue e85 reacts badly to aluminium, albeit poor quality aluminium none the less.
do most just run stainless set ups, or is it just the luck of the draw with aluminium?
Edited by Dan_J
Just make sure the surge tank has been anodised properly.
I believe the likes of Aftermarket Industries and Radium both state their tanks are 100% E85 compatible.
I've got several mates (mainly in the EVO game) running these surge tanks with just plain old boring $10 Ryco fuel filters with no issues what so ever.
Then again, like myself they always blend in 98RON when the car will be sitting around for long periods.
  • Like 1
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
