Hi guys,
I have some gear for sale.
- All items are located in Georges Hall, Sydney (2199).
- Postage is paid by the buyer.
- NO paypal!!!
- Upon delivery, please inspect items and if they are not as I have described then please let me know. You have 7 days from date of delivery/pickup. This is a condition of sale. I am not interested in you coming back to me after 6 months!
- If you require further photo's I will gladly take more and send them to you.
1:
Item: Apexi power intake
Condition: Fine. used for approx 5000 kms. Wont be needing it due to going single turbo. There is a little bit of surface rust on the brackets but a quick sand and a paint will sort that out.
Price: $200
A29DB344-0B69-4354-9F5E-11A325D14EAA_zps
B56203EF-72D3-4298-BCEE-9D8E6C5FD383_zps
EC921DC3-9BCF-4557-A131-DA8ABC23506A_zps
2:
Item: Under boot surge tank. It was on my R33 GTR and holds 2 x 044's. I will throw in the pumps (2 of) however I don't know what sort of condition they are in. The Feed/Overflow and return bungs are -8.
Condition: It could do with a clean and a repaint.
Price: $200
B38E848B-DDBC-45EC-BEEE-8E30CF4D6F65_zps
8BA16E78-1A27-49BF-9126-8A5F2E883B91_zps
E28E64E0-A93E-4D1D-AA8D-96398A88F6D5_zps
3:
Item: HKS Twin Turbo hard piping kit. This goes from the back of both AFM's and deletes the stock rubber piping.
Condition: Fine. A quick polish and it will look good as new.
Price: $300
28DFC3A3-693E-409F-A58C-726849E7B14B_zps
4
Item: Hypertune airbox and Titanium lobster back intake pipe with K&N pod filter (RF 1015). This was made with a combination of a 6 boost exhaust manifold, Borg Warner EFR 8374 (9180 will fit also) and an R33 GTR.
Condition: Perfect. It was made and i've decided to change it. Engine has not run with this setup on it.
Price: $1,000
28C48F21-6CAB-4838-AE10-02452D0B6664_zps
This photo is of a mates car. Box is identical but he just had allow piping done. I have shown this photo as it gives a better indication of how it all sits.
4A2AA073-54A8-4AFB-BFC2-9E2F50350777_zps
5
Item: Nismo gearbox mount.
Condition: Fine. Used for approx 10,000 kms.
Price:$50
Price:FF22ED1E-35FF-4E5F-9798-D864FC0175CC_zps
92BD9A5F-A757-4A01-B289-C97EB5E47738_zps
6
Item: Haltech EGT sensors and bungs.
Condition: Brand new. One packet was opened for photo purposes only.
Price: $600
FE6A7E0D-85D3-4D80-855B-7DE9DBF6794E_zps
FC1C1675-C431-4CE1-AC12-BEBBF63D8300_zps
1EC7A066-BA6E-4F0D-B98A-EA797144B689_zps
Item: Holley Dominator 12-1800 fuel pump
Condition: Fine. It came off GTR NUR's R34 GTR. It was used for one dyno session and was in the car for approx 2 weeks. I would have used it but I changed how I wanted to layout the fuel system.
Price: $350
27D85DE6-CDA9-44AC-A2B7-6B002E66EA3B_zps
62AF46C6-3F90-4B55-B353-910C8C45D63C_zps
8
Item: Turbosmart FPR 2000
Condition: Fine. Came off my car in working condition.
Price: $200
00DBE98E-AF00-450C-A816-18DA2AF01FED_zps
DE9DAE7B-C8AF-4974-BB9A-23C8858A33F4_zps
7D2BE3AE-B7D5-47B0-924C-2EDD964EA4BA_zps
DE9E0BCE-3DE0-4038-B539-089BEF0B1A9D_zps
Cheers,
Paul.
  • Like 3
https://www.sau.com.au/forums/topic/466289-garage-sale/
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
