R32 GTR misfire. O2 sensor readings.
Hey everyone, hoping I can get some insight into this..
I've chasing this misfire since months. Engine boggs heavily when cold until coolant temp reaches 60 degrees celcius. Clears up as soon as it hits that mark.
Engine misfires heavily under high load above 4000 rpm. 10 psi boost.
Engine is bone stock. Stock ECU.
Work done so far:
-New coilpacks and harness.
-Spark plugs BCP7ES gapped to 0.8mm
-Fuel pressure and injectors ok. New fuel filter. 12.4 volts at fuel pump.
-Smoke tested- found air leak and replaced all 7 intake gaskets and all hoses underneath. Smoke tested again - no air leaks now.
-Swapped CAS. no change
-Swapped MAFs. no change.
-swapped boost solenoid. no change
-swapped coolant temp sensor. no change.
-Base and ignition timing is on point.
Now i'm looking at o2 sensor readings. They don't seem normal to me but I would just like to confirm with anyone with more diagnostic experience than me. Here is the data from ECUTalk via consult.
Idle after hitting closed loop: 0:00 - 0:25
Shy revs: 0:25 - 0:30
Idle : 0:30 - 1:00
Hold rpm 1300: 1:00
Please. I will appreciate any input.
Thanks!
Edited by gotenek
https://www.sau.com.au/forums/topic/466476-r32-gtr-misfire-o2-sensor-readings/
Unplug them and see if the car drives better...
Have you tried swapping the ignition unit on the valley cover with a known working one?
I presume all parts were swapped with known working items?
Have you done a comp test?
I will try unplugging them thank you.
I converted to r34 gtr coilpacks so ignitor pack was deleted.
Yes eveything was from good running friend's car
Yes. Compresion test yielded even 160 psi on all cylinders while engine was hot.
Boroscope each cylinder. Valves and cylinders looked ok. Just a little bit of oil around the piston rings but thats understandable at 155,000 km.
Did this problem occur when you did the swap to 34 gtr coil packs?
Just stabbing in the dark but maybe that's your issue...
No unfortunately not.. its been there since a long time preventing me from driving the car
don't run them... you'll have shit fuel economy for now.. but at least the OEM ECU won't add in any funny fuel trims for both short and long term...
once you're ready, get an aftermarket ECU and feed a wideband o2 into it.
Sounds like you have electrical gremlins.
  • Like 1
Don't run what? Are you suggesting that my o2 sensors are okay?
unplug both o2, don't bother running them - downside is you'll have crappy fuel economy but that's Skyline life.
Oh i see i will try that as Hadouken suggested as well. I have new o2 sensors coming in 2 days. Just wanted some input on my current ones
New or used Engine coolant temp sensor swap in?
Check the wiring and the grounding and use a new one for $50 (kudos motorsport)
Used one from a friend's properly running car. I've checked wiring. Didnt see any voltage drop
  • Like 1
Put a scope on the negative of all the cylinders. #6 seems to be dropping below 5v. I'm not sure of what to derive from this. Checked resistance from signal wire to ecu for all cylinders and they are all at 0.182 ohms. Checked ground for Coilpacks. Resistance was nominal. Checked CAS signal wires (2) as well and they are a 0.145 which seems nominal.. I think
Swapped ECU from a friend's good running gtr. No change.. lol
Cylinder 6:
Rest of the cylinders:
If the engine is stock, and the coils are good, then open the plug gap out to 1mm. Also, you seem to have the wrong heat range plugs - the correct heat range is a 6.
BTW - I've lost count of the number of times I've had to say that the O2 sensors are ignored under anything but cruise conditions. So if you are on boost, the O2 sensors play absolutely no part in how the engine runs.
  • Like 1
I've gapped the spark plugs again to 1.1mm recently and no change.. And yes, they are bcpR7es NGK 6282 (typo haha).
The rpms start breaking up anything above 4000 rpm. The higher the load, the worse the misfire really.
Yes also that's cruise when the engine is up to temperature, and OPs problem is when the engine is cold.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
