Basically my op6 r34 turbo is dead, for a quick fix will the 21u r33 turbo (highflowed) as i can't afford the gtx3076 just yet but need the car on the road. As far as I'm aware it'll bolt on, and being highflowed would assume it'd be same/better than a standard op6?
https://www.sau.com.au/forums/topic/466678-21u-highflowed-onto-a-34-neo-engine/
It will be much better than a standard op6. You will need to have your car tuned if u want anything decent out of it. Otherwise you can run it as is at say 10 psi untuned and it will be ok and perform roughly about the same as your op6.
Will be better than the standard op6
Recently went from op6 highflow to 21u highflow on r34, hoping to achieve better response, haven't started car yet so can't really comment since I'm getting a whole lot of other stuff done to it too. but I hope it'll achieve good response and make around 260rwkw region
Awesome thanks guys, just after a quick fix for now so the car is driveable so 10psi will be fine.
Gearbox needed rebuilding, turbo went and then got rear ended to top it all off, all in 14 days. So unfortunately the turbo got the quick/cheaper fix for now
How did you go with the retune man? Was the op6 really laggy?
Will find out soon, still busy finishing off some of the work on the car
I've had 21U highflow from precision, OP6 from GCG and OP6 from hypergear throughout the few skylines I've had and I preferred the 21u.
Managed almost 280rwkw on 20psi from the OP6 hypergear but the OP6 highflow doesn't really see full boost until 4000rpm
It'll hit full boost slightly earlier on the 21U. But I think the biggest difference is partial throttle response, where it matters the most in everyday driving.
Seeing that Hypergear is getting some good results from the 21U i thought I'd swap the rear housing over. Will report back once it's ready to go
Yeah that sounds about right, I managed to get 397kw on a hypergear op6 highflow..minor spike to 22 psi then drops down to 20 psi. Looks like I will be getting a 21u housing machined up. Thanks for the reply and good luck with your car!!
  • 4 months later...
Wow that's a crazy good result! E85 I'm guessing?
15 hours ago, dc2low said:
Nah mate, bp98.
Is that a typo? 397kw? did you mean 297kw?
Cause damn, 397kw on a op6 higflow on 98 is wizardry.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
