Front 20x8.5 +25 245/35 tyres fitment stance offset wheels for v36 skyline coupe.
Rear 20x10 +40 with 275/30 tyres.  could prob even run 295 tyres on the rear 295/30/20 tyres
Vossen VFS1 - Matte Graphite
Wheels:
  • Front: 20x9.5" +25 (Mid Concave)
  • Rear:20x10.5" +40 including 5mm hubcentric spacer (Deep Concave)
Tires:
  • Front: 245/35R20 Continental DWS06
  • Rear: 285/30R20 Continental DWS06
Edited by R377
Rays Mercury Silver gt30's, front 20x9.5 +20, rear 20x10.5 +27, 235/35/20, 265/30/20
Although i spaced them out a little more with a 5mm spacer.  fronts +15 with 235/35 and rears +22 with 265/30.
Rear has maybe 2mm clearance to fender, but no rubbing, and front has 5mm. Front only rubs when i have another person in the car while doing a u turn, but very slightly.
Volk GT-S Mercury silver
19 x 9.5 +17 225/40/19
19 x 10.5 +28 275/35/19
Tein S-Tech springs
rears do rub on big bumps or dips. Im debating going to a 255 rear....not too sure about that yet though
20" Volk GT30 Formula Silver
Front: 20x9.5 with +35 offset
Rear: 20x10.5 with +37 offset
Tires
Yokohama S Drive Tires
Front: 245x35x20
Rear: 285x30x20
Rubbing
No. Liner trimmed and fender bracket completely dremeled. Rubs on big dips on highways though
From Tasmania
Volk GT30
20x9.5 +37
20x10.5 +35
Tyres:
Kumho KU31 ECSTA SPT
F 245/35/20
R 285/30/20
Suspension:
KW-V3 coilovers
Rubbing:
After trimming lining & rear bar mount, only on heavy dips.
  • 6 months later...
19x9.5 +30 Front 255/35/19 (leftover from last setup, will switch to 245 or 255 40/19 when these are done)
19x10.5 +30 Rear 275/35/19
Overall, i would maybe run 5MM spacers in the front, to match the rear poke...
Alignment specs are at -0.8 front, -2.0 Rear
Decided to pull the 295 off and save them for a different build. Went with a 275 35 instead. With the added room i was able to lower it where i wanted and keep -2.5 camber.
So the specs are now 19x10 +30 275 30 front
19x11 +20 275 35 rear. When the fronts go ill probably run 275 35 19 all around.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
