Nissan R32 & R33 GT-R standard parts
For sale is some standard R32 & R33 GT-R parts I have lying around that I don't intend on using.
R32/ R33 GT-R Harmonic Balancer
For sale is a R32/ R33 GT-R Harmonic Balancer. Both have minor chips in them due to a jack clipping it. My mechanic said that this chip won’t make a difference at all but just to make sure it’s best to check in with your mechanic if interested. These harmonic balances were in a box of parts I bought to put my R32 GT-R back together. I have no need for them hence why I am selling.
$30 each
RB26 R32/ R33 GT-R twinturbo pipe
Bought a box of spare parts to get my R32 GT-R back on the road and I had a extra twin turbo pipe.
$150
R32 GT-R stock exhaust
For sale is a standard R32 GT-R exhaust perfect for EPA clearance. Exhaust is from the dump pipes back with a cat. Bought this exhaust to clear an EPA however its no longer needed.
$150
R33 GT-R standard dump pipes
Came in a box of spare parts and I have no need for it. This is R33 GT-R dump pipes which are ever so slightly different to R32 GT-R ones.
$100
R33 GT-R wiring loom
Good condition R33 GT-R wiring loom minus the plastic cover that goes of the injector harness of the loom. Wires are not brittle or split; they are in very good condition. This came with the box of parts I purchased for my 32 GT-R. I have no need for this loom.
$150
R32 GT-R standard CAM gears
$50
R33 GT-R gear shifter surround and handbrake boot
$20
Delivery: I won't get anyone delivery quotes. A rough estimate can be viewed using the Australia Post Delivery Calculator.
Contact: Please PM or call me on 0413 029 099.
Cheers!
Edited by manage13
Forgot the exhaust pic
https://www.sau.com.au/forums/topic/466755-nissan-r32-r33-gt-r-standard-parts/
  • 1 month later...
  • 1 month later...
    • Had I known the diff between R32 and R33 suspension I would have R33 suspension. That ship has sailed so I'm doing my best to replicate a drop spindle without spending $4k on a Billet one.
    • OEM suspension starts to bind as soon as the car gets away from stock height. I locked in the caster and camber before cutting off the kingpin. I then let the upright down in a natural (unbound) state before re-attaching it. Now it moves freely in bump and droop relative to the new ride height. My plan is to add GKTech arms before the car is finished so I can dial camber and caster further. It will be fine. This isn't rocket science. Caster looks good, camber is good, upper arm doesn't cause crazy gain and it is now closer to the stock angle and bump steer checks out. Send it.
    • Pay careful attention to the kinematics of that upper arm. The bloody things don't work properly even on a normal stock height R32. Nissan really screwed the pooch on that one. The fixes have included changing the hole locations on the bracket to change the angle of the inner pivot (which was fairly successful but usually makes it impossible to install or remove the arm without unbolting the bracket from the tower, which sucks) and various swivelling upper arm designs. ALL the swivelling upper arm designs that look like a capital I (with serifs) suck. All of them. Some of them are in fact terribly unsafe. Even the best one of them (the old UAS design) shat itself in short order on my car. The only upper arm that works as advertised and is pretty safe is the GKTech one. But it is high maintenance on a street car. I'm guessing that a 600HP car as (stupidly, IMO) low as you are going is not going to be a regular driver. So the maintenance issues on suspension parts are probably not going to be a problem. But you really must make sure that however your fairly drastically modded suspension ends up, that the upper arms swing through an arc that wants to keep the inner and outer bolts parallel. If the outer end travels through an arc that makes that end's bolt want to skew away from parallel with the inner bolt, you will build up enormous binding and compressing forces in the bushes, chew them out and hate life. The suspension compliance can actually be dominated by the bush binding, not the spring rate! It may be the case that even something like the GKTech arm won't work if your suspension kinematics become too weird, courtesy of all the cut and shut going on. Although you at least say there's no binding now, so maybe you're OK. Seeing as you're in the build phase, you could consider using R33/4 type upper arms (either that actual arm, OEM or aftermarket) or any similar wishbone designed to suit your available space, so alleviate the silliness of the R32 design. Then you can locate your inner pivots to provide the correct kinematics (camber gain on compression, etc).
    • The frontend wouldn't go low enough because the coilover was max low and the upper control arm would collapse into itself and potentially bottom out in the strut tower. I made a brace and cut off the kingpin and then moved the upright down 1.25" and welded. i still have to finish but this gives an idea. Now I can have a normal 3.25" of shock travel and things aren't binding. I'm also dropping the lower arm and tie rod 1.25".
    • Motor and body mockup. Wheel fitment and ride height not set. Last pic shows front ride height after modifying the front uprights to make a 1.25" drop spindle.
