G35 front calipers onto R34 25gt
Essentially the title says it all, have people done this conversion on a skyline before? I've mainly seen it done on Silvias to great success since they either swap in gtst or brembos from skylines anyways.
I would assume the swap onto an N/A r34 would be identical to gtt swap just needing the uprights drilled to14mm.
Would be a decent upgrade from the 280x26mm rotor to a 320x28 from the g35. Biggest reason behind this route is that I'm located in Canada and sources parts for skylines is quite difficult quickly so I decided to try and swap it to a domestic vehicle with plenty of stock for less headaches.
Thanks for any one with more info on this setup!
Edited by hugh jaynous
Typo
https://www.sau.com.au/forums/topic/466823-g35-front-calipers-onto-r34-25gt/
Hi mate, I'm not specifically familiar with G35 onto R34 swap, but generally the 32/33/34 series stuff is interchangeable but 35 and later use a different offset disc and caliper that may or may not fit. So G35/V36, M35, Z33, V36, Z34 etc all interchange but not necessarily with an r34.
If you are able to do a trial fit I'm sure the v35 stuff would be much easier to find in canadia than any of the other ones except perhaps a Z32 aftermarket big brake kit
i see, for the most part im purely trying to get a grasp of how they would fit from a reference point of this thread, http://zilvia.net/f/showthread.php?t=560515 which shows the guy had done the swap from the g35 onto an s13. As stated in the article himself the bolt patterns are the same but the rotors themselves would need replacing to match the g35 along with potentially cutting some of the caliper mounting bolts for clearance issues. Thanks for any more information though!
Just going to continue this thread into a build log with how things have progressed and if they fit etc. The calipers themselves have arrived and are very similar in sizing to the stock 2 pot sumitomo in the R34 25gt  bolt patterns are identical but pads seem quite a bit larger than the R34 ones. Waiting on rotors to come in to do complete mock up before drilling out the holes to 14 to fit the new caliper bolts.
I thought about the helicoils, unsure if the bolt hole for m14 bolts is too large for an m12x1.25 helicoil (12.3mm for m12x1.25 helicoil and the m14x1.25 bolt hole is already 12.8? Or so not sure) Will have to look into it for sure since can't really reverse drilled hubs easily.
No clue what happened with all the quotes, on mobile so posting got a little messed
The threads in these things are inserts that can be removed and changed to the other size anyway.
Contact this spanker http://www.sau.com.au/forums/profile/107339-ben-c34/ to see if he still has any of the 12mm inserts.
Edited by GTSBoy
Oh snap you wouldn't happen to know how much for those sleeves would you? By far the drilling out of the hubs does set the car up easier for m14 Brembos and what not in the future when I add more power, but the sleeves right now would be great to guarantee a dead level fit.
So the pictures attached are the before and after of the G35 brakes install. I didn't realize it but the bolts on my skyline were identical to the ones that the g35 came with. The digital caliper I used to measure the bolt diameter at the threads were identical. 13.7~mm for both bolts. No drilling needed even though I'm fairly certain that the brakes are m12x1.25 bolts for the r34 25gt same as r33 gtst etc.
Definitely fills up the wheel a lot more and the space between caliper and wheels are greatly reduced as the disk is a 320mm/12.58inch disk vs the 280mm disk on the NA skyline.
Photos added
Looks great! Have you got a photo with the wheel off? The front seems to have a lot more rotor area than the stock R34 GTT 310mm discs, more than the 10mm diameter difference would suggest.
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
