G35 front calipers onto R34 25gt
Essentially the title says it all, have people done this conversion on a skyline before? I've mainly seen it done on Silvias to great success since they either swap in gtst or brembos from skylines anyways.
I would assume the swap onto an N/A r34 would be identical to gtt swap just needing the uprights drilled to14mm.
Would be a decent upgrade from the 280x26mm rotor to a 320x28 from the g35. Biggest reason behind this route is that I'm located in Canada and sources parts for skylines is quite difficult quickly so I decided to try and swap it to a domestic vehicle with plenty of stock for less headaches.
Thanks for any one with more info on this setup!
Edited by hugh jaynous
Typo
https://www.sau.com.au/forums/topic/466823-g35-front-calipers-onto-r34-25gt/
Hi mate, I'm not specifically familiar with G35 onto R34 swap, but generally the 32/33/34 series stuff is interchangeable but 35 and later use a different offset disc and caliper that may or may not fit. So G35/V36, M35, Z33, V36, Z34 etc all interchange but not necessarily with an r34.
If you are able to do a trial fit I'm sure the v35 stuff would be much easier to find in canadia than any of the other ones except perhaps a Z32 aftermarket big brake kit
i see, for the most part im purely trying to get a grasp of how they would fit from a reference point of this thread, http://zilvia.net/f/showthread.php?t=560515 which shows the guy had done the swap from the g35 onto an s13. As stated in the article himself the bolt patterns are the same but the rotors themselves would need replacing to match the g35 along with potentially cutting some of the caliper mounting bolts for clearance issues. Thanks for any more information though!
Just going to continue this thread into a build log with how things have progressed and if they fit etc. The calipers themselves have arrived and are very similar in sizing to the stock 2 pot sumitomo in the R34 25gt  bolt patterns are identical but pads seem quite a bit larger than the R34 ones. Waiting on rotors to come in to do complete mock up before drilling out the holes to 14 to fit the new caliper bolts.
I thought about the helicoils, unsure if the bolt hole for m14 bolts is too large for an m12x1.25 helicoil (12.3mm for m12x1.25 helicoil and the m14x1.25 bolt hole is already 12.8? Or so not sure) Will have to look into it for sure since can't really reverse drilled hubs easily.
No clue what happened with all the quotes, on mobile so posting got a little messed
The threads in these things are inserts that can be removed and changed to the other size anyway.
Contact this spanker http://www.sau.com.au/forums/profile/107339-ben-c34/ to see if he still has any of the 12mm inserts.
Edited by GTSBoy
Oh snap you wouldn't happen to know how much for those sleeves would you? By far the drilling out of the hubs does set the car up easier for m14 Brembos and what not in the future when I add more power, but the sleeves right now would be great to guarantee a dead level fit.
So the pictures attached are the before and after of the G35 brakes install. I didn't realize it but the bolts on my skyline were identical to the ones that the g35 came with. The digital caliper I used to measure the bolt diameter at the threads were identical. 13.7~mm for both bolts. No drilling needed even though I'm fairly certain that the brakes are m12x1.25 bolts for the r34 25gt same as r33 gtst etc.
Definitely fills up the wheel a lot more and the space between caliper and wheels are greatly reduced as the disk is a 320mm/12.58inch disk vs the 280mm disk on the NA skyline.
Photos added
Looks great! Have you got a photo with the wheel off? The front seems to have a lot more rotor area than the stock R34 GTT 310mm discs, more than the 10mm diameter difference would suggest.
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
