absolutely, the block and cradle are a pair. Even when they come together from the the same engine they should still be measured and potentially machined to make sure the main bearing clearances are correct.
  • Like 1
https://www.sau.com.au/forums/topic/467094-rb30-girdle/#findComment-7780959
so what can i do ? i have a block but no cradle, does that mean my block is useless ? do i just need to find a cradle and get it machined to suit block ? can i buy a new cradle from spool and get that machined to suit ? im lost
https://www.sau.com.au/forums/topic/467094-rb30-girdle/#findComment-7781608
Would almost be easier to keep your eye out for another complete block.. There's quite a few on facebook sale pages at the moment.
https://www.sau.com.au/forums/topic/467094-rb30-girdle/#findComment-7781610
I know it's not great news, and no you are not lost, they are pretty much your choices.  I'd either buy a different block (probably cheapest option) or buy a new cradle if that's an option (I assume its aftermarket and a different style). If you choose the latter you need to get the block tunnel bored which I don't really like in these engines because it moves the crank relative to the oil pump
https://www.sau.com.au/forums/topic/467094-rb30-girdle/#findComment-7781979
12 hours ago, Scott Black said:
with that ill just need to tunnel bore it right ? my block is 87mm and already been machined and cleaned n decked, so im not looking to buy another block, most likey just buy that girdle and machine it to suit right ?
https://www.sau.com.au/forums/topic/467094-rb30-girdle/#findComment-7782314
I could be wrong but I'm pretty sure you need to buy the Spool girdle in conjunction with their main cap kit which is another $1600 or so.  I could be wrong but I'm pretty sure that's how it works.  You can get the mains on their own but not the girdle on it's own.
https://www.sau.com.au/forums/topic/467094-rb30-girdle/#findComment-7782322
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
