Wanting to buy R34 GTR Wheels
Hello! ,
Just putting the feelers out there for this one.
Wanting to buy (a set of 4) R34 GTR Wheels that are in good nick, or considerable condition  (Don't want anything that has buckles or cracks please)
Must HAVE center caps and MUST BE in original colour (Don't want resprayed or powder coated another colour too), and whether or not they have tyre's is no big deal to me.
Anyway, any helping me find a set would be much, much, much appreciated.
Thankyou,
Seanski96.
https://www.sau.com.au/forums/topic/467108-wanting-to-buy-r34-gtr-wheels/
Hey Sean
I've got a set on my 32GTR currently with Federal 595 255/40/18 with loads of tread all original all complete.
Passenger rear has 2cm (max) minor rash the rest are unmarked, this is an easy repair.
Let me know and I'll shoot all 4.
Whats your budget?
Where are you located?
15 minutes ago, andyseven said:
Hey Sean
Whats your budget?
My budget is $1500, more or less depending on condition. I'm located in Sydney NSW. Will edit the ad for future sellers too.
As I can't seem to edit my original post. Just as future reference, my budget is $1500 (More or less depending on condition etc.) and I'm in the CBD Sydney region of NSW.
23 hours ago, Terry_GT-R34 said:
Just letting you know seanski that there are two original colours.
Hey Terry, I just found out today actually that there are two variants of the "original colour", was moreso just saying it as a general term. But something has come up and I have to close this thread as I'm unable to buy the wheels now.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
