Whiteline Swaybar Links vs WL Pin Eye Link?
I got two options mounting my rear sway-bar links.
One is the Pin/Eye type (comes with the sway bar), the other option are the links shown in the picture (right).
The links on the right side have no bushings at all, how does that affect the operation of the sway bar?
Cheers!
don't worry, the 2x ball joint type are OEM style in lots of applications including GTR front.
They do wear out and start to bind or clunk though, and I guess are more expensive
  • Like 1
(unrelated response).
I once was all over the suepr thick ARBs and all.... now wished I didn't bother upgrading them.. I have both my mine on the softest settings for track use.. the ARBs just made the car super duper twitchy and sketchy.
Even MCA said to use stock.
Because I'm stubborn and didn't listen I bought thick ones, and kept snapping the mounts that hold the links up front lol
What do you mean by super thick though?  Is that the 24mm territory or the 27mm territory?
24mm 24mm, wanted 27mm 24mm at the time using the SydneyKid methodology with super thick ARBs and shit soft spring rates.
Guess that's good for street use, but track wise was aids.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
