8 hours ago, WantGTR said:
f**king neat.
Not as neat as yours bro!
I need to make it look good, get internet points and sell the car. Will probably be extremely bored/sick of it once it's ready. So over it, if someone traded me a F30 335i I would take it.
I have more pleasure driving the Tiguan lol
Run a number and post a 2 step video in insta. Will get made efame and sell car for top bucks.
Vw's are so good hey?
So good, even remembers who I am, greets me by my name and remembers all my settings (volume, AC settings, drive settings and everything else). No keys, no buttons just thumb on the handle and she comes to life.
Has launch control too ?
No idea why I keep building the stupid R33, maybe there's light at the end of the tunnel or it's just stupidity.
  • Like 1
You can take the boy out of cabramatta but you cant take the cabramatta out of the boy ?
Its in your dna bro
Its in your dna bro
LOL.. you're actually wrong, if I was a true Cabra boy I would have some f*kBOY Gucci bum bags, Gucci shoes and a Honda or 86 homosex car.
Correct but r33 is the og must have import
Has launch control too [emoji23]
What model Tiguan did you get?
And I wonder why I still keep my GTR when my Golf R is doing what I want it to do.
162TSI Sportline, has all the fancy R-Line features except the dash, kit, 360 bird's eye camera and xenons but I have LED high/low beams and 20" wheels instead LOL...
That's right, Golf MK7 motor with haldex however with the beefy DQ500 gearbox.
Doesn't feel as derpy as DQ250 box and loves the LC lol.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
