Took the shit box out with other shit boxes. Smashed the limiter again in 2nd a few times, I still haz PS belt.
Great success.
  • Like 6
1 hour ago, admS15 said:
No need for an M3 anymore then... Did you chop the Evo?
Evo chopped itself, exhaust manifold cracked.
NA 4G63T lol..
Nah, would still take a F80 LCI M3 if someone is retarded enough to swap.
  • Sad 1
1 hour ago, r32-25t said:
Evo3!! so pretty
He will be at All Jap Day too!
Just needs his manifold fixed before then.
  • Like 1
2 minutes ago, r32-25t said:
At the moment I still don’t have a running car and it’s like 14 weeks away
You're nearly done, what are you on about?
Made a temporary, maybe temporary permanent heatshield for the ABS pump, loom wiring.
Should stop things melting on the circuit after a few laps.
It's a bit ugly, but better than a pile of molten wiring at the track.
If money permits, might use those Real Thermal guys and wrap the gate, housing and dump.
  • Like 3
I'm surprised you think it looks ugly, I think it looks great.
I'm not sure if this would effect how well it works, but painting it black might help it blend in with the background if that's what you'd prefer.
Thanks mate, I might try hitting it with engine enamel black.
Might make blend in a bit more.
Test and Learn tonight, pray to all the 33 gods out there, and the Skyline gods nothing breaks or fails.
  • Like 2
It's alright, good to use the car instead of looking at it.
Will upload my PB lap soon, just trying to see why I can't get any of the telemetry from the VIRB. Probs dropped it a few too many times lol.
    • Let large companies that are making money off selling kits do the preliminary engineering for you. If they all do -10, then that is all you'll ever need.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
