R34 25GT-FOUR
Hello everyone, i have been looking up some information on a R34 25GT-FOUR that i might be buying soon, the question i'm trying to find an answer to is the AWD system, is a the same setup as a torque split or is it always in 4wd mode. A few sources have said its always in 4wd mode and others say its 2wd until traction is lost. What makes it more confusing is that it is running a R33 RB26DETT engine with a R32 gearbox.
Thanks
https://www.sau.com.au/forums/topic/468359-r34-25gt-four/
The R34 atessa is always on - supplying 5% to the front until the computer tells it to increase it.. Despite the fact that it has an R32 box (why??) it will not behave like an R32GTR where you can disable the awd by pulling a fuse. If you want 2wd you can drop the front driveshaft or there is there a procedure you can go through which is not simple.
https://www.sau.com.au/forums/topic/468359-r34-25gt-four/#findComment-7801526
Awesome, thanks. I'm not to sure why it has a R32 gear box, it used to be a RB25DE auto and has been converted to manual, which also brings up another question. At the moment the speedometer is not reading the correct speed and the cluster is still the auto cluster, replacing the cluster with a manual wont fix the speedometer problem? I'm assuming that ill need to get a speedometer corrector installed.
https://www.sau.com.au/forums/topic/468359-r34-25gt-four/#findComment-7801528
Probably the speedo is wrong because the speed sensor pinion from the gt four wasn't fitted into the R32 gearbox. The gt four has 4.34 diff gears, whereas gtr has 4.11, so you need to use the correct speedo sensor pinion.
I have a R33 gtr gearbox in my R34 gt4 - in fact you can swap an auto 4wd gearbox speedo sensor into the manual box. This is what i did.
In other words, you need the R34 gt four speed sensor, to match your diffs. Note that I'm assuming the car has kept the 4.34 diffs, not swapped to 4.1. Either way, they just have to match.
https://www.sau.com.au/forums/topic/468359-r34-25gt-four/#findComment-7801538
I have read varied opinions regarding whether the factory electronic sensor from R33/R34 will or won't fit into the R32 box. I haven't tried it. Did some research though, the speedo drive gear on the output shaft is the same, R32 to R33. I think even the rear housing is the same.
Also, correcting myself from above, GT four is factory with 4.363 gearing.
https://www.sau.com.au/forums/topic/468359-r34-25gt-four/#findComment-7801749
  • 1 month later...
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
