Tomei oil pump failures
I tried searching but ran across the spline drive oil pump conversions and hadn't really heard bad press about the Tomei oil pump until then. I read about ONE failure so far and the thread did not provide Tomei's resolution to the pump issue so I'm curious if this is actually a potential problem or not.
I have a Tomei pump and am curious if anyone has seen one broken and under what circumstances. I'm limiting my car to 8k, but I do bang the limiter quite frequently and was just thinking about going a bit higher soon. Some say the cause of failure is oil cavitation from temporarily starving the pump (which means a dry sump would be the only real cure), and some say it's simply the 2-flat-drive stock pump orientation that kills oil pumps. I'm looking for actual evidence if possible because I'd like to live the rest of my engine's life in a happy state of knowing the chances of oil pump failure are very slim.
Patrick
https://www.sau.com.au/forums/topic/468441-tomei-oil-pump-failures/
If that Tomei pump failure was with the spline drive fitted then there lies your answer. They will not tolerate any misalignment and will load the driven gear radially and also fretting/galling on the splines.
Nitto wrote a good answer somewhere on here why they will not release a spline drive yet due to reliability issues.
You have the stroker crank with full width pump drive I guess, what sort of balancer are you running. I've been running a  1000hp ATi for a long time now, and when I pulled it all down for some checking last year it was all good with minimal wear thanks to ATI, but no limit bouncing here.  .
However if you like bouncing on the limiter a bit then something will eventually give ...dry sump it and you can bounce of the limiter all day long :devil:
I have never heard of a Tomei pump failing (which is not to say it doesn't happen). If you fit oil restrictors when you fit the pump and you overfill the sump by a litre OR preferably have an enlarged sump there is no reason why your pump should starve (i.e. a dry sump is not mandatory).Stop limiter bashing. Raise the limit on your ecu (I assume you have an aftermarket one) and put a stop under you accelerator pedal or adjust the limit stop (depending on your set up) to limit the revs.
I do have Tomei head restrictor, Greddy Sump (Which the Tomei tells you quite clearly you shouldn't run in some of it's settings without a larger sump), and N1 block (which has larger drain ports back to the pan), also mine's baffles and rear "drain" if anyone cares about that anymore. And I'm on the Fluidampr balancer (seems really nice).
Also yes Haltech...I hit the 2 step limiter when launching everytime but if I spin the tires the car racks out so fast in first that it hits the limiter quite quick on top. It IS a soft touch limiter though which at least isn't as hard as a hard cut. I'll bump the revs to 8500-8700 and use Haltech to output a shift light and try to just stay off of it. But yes thanks for the info. Also I do have the Haltech reading oil pressure and use the "engine protection" feature to put it in limp mode when it senses oil pressure low or high out of range.
I'm not sure the guy was spline drive, but I ran across the thread (not on this forum) after someone asked me if I had converted mine to spline drive.
And yes BC billet stroker crank. Engine runs really smooth with the balancer, crank, heavier nismo coppermix, etc.
Thanks!
  • 1 year later...
They have in some cases become oval and caused binding and lock up of the oil pump. Nothing to do with Spline Drive. We do however have Spline Drive upgrades for most pumps and the theory they bind due to crank flex is just a myth. Both ourselves Supertec and Spool have been selling these for the past 4 years. Zero gear failures reported to date for our kits.
Edited by Frracer
  • 5 months later...
Nitto are not the authoritative answer on oil pumps or spline drives. Can respect their own findings maybe it wasn’t so successful based on what clearances and spline profile they tested with. We carried out our own R&D prior to launching them in 2014. We have successfully been selling spline drive kits for almost 5 years now with over 900 kits sold and yet to see the “Nitto theory” come to life..... Ironically our Jun kit fits the Nitto pump. Have a good few customers running a Nitto pump with a spline kit. That in my view is an anwesome pump because Nitto did use better materials and a billet 7075 back plate compared to Jun/Greddy.
Edited by Frracer
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
