Hi,
If some one have/had gauge like this can tell me how to connect it properly?
I have 2 connectors, 1 is for gauge and I connect all wires, 1 is for sensor and from sensor connector i have 3 free wire:  gray, green, and brown.
The problem is my Warning don't work, I set it from behind at 2.0 bar but when i test and pump over 2 bar the red LED doesn't blink :( And when i connect brown wire to black wire from gauge it blink all time.
So my question is how to connect it properly ?
Edited by Snara
Got photo of the receiver/sender unit?
I had the same problem with my old Tomei gauge but i worked it out.
Basically .....
The gauge itself has Black/Earth, Red/Power, Orange/Accessory, Yellow/Gauge light
Then 3 extra wires from gauge to Sender/Receiver unit, these are just Earth, Constant and Accessory.
My only problem was the Accessory and Gauge light wire's color so faded i couldn't tell which is which so i wired them both together.
As for warning lights .... i'm yet to know how to set them. The Tomei has 2 buttons at the back and one at the front of the gauge. Mine flash RED at 5psi and then at 15psi. Obvious there are 2 pre-warning and a recall.
9 minutes ago, Snara said:
Damn :( I have only gauge and sensor.
So without unit i can't use warning? shit :(
No ....
Maybe HKS built it differently so gauge and sensor is all you needed. You mentioned you tested it at 20psi so you must have connected the boost vacuum line and all is working right?
I'm sure you can use warning, just have to try to figure it out.
Yea, i have connected boost vacuum line and it show me boost and underpressure but warning don't work. It should turn red led when i exceed the target pressure which is set to 20 psi but red led is turned on all time :P
So no one on that forum never have that HKS boost gauge and can't tell me some hint? :D
Edited by Snara
Sure, first what i do i search on google, it's many threads but i don't find any HKS wiring diagram or problem with warning:(
So i need someone who know that old HKS gauges :D
My friend make video, looks like that gauge need some unit for working warning :
  • 1 year later...
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
