BCNR33 Vs BNR34 front brake caliper threads
Hi,
I have a set of R33 GTR Brembo front calipers.
They came without the hard lines or any brake lines or fittings but do have the "olives" still on them.
I wanted to retain the factory flared hard lines so i bought a set of BNR34 hard lines with aftermarket braided lines since both BCNR33 & BNR34 share the same part numbers in both Nissan & Nismo data.
I tired fitting them to the calipers but they do no't seem to fit due to a different thread on the caliper and hard line bolt,
Do BCNR33 & BNR34 front calipers have different threads?
Thanks!
Mebbe....but I think he means the thread where the brake line goes into the caliper.  I don't know if they are different but I would have thought 99% they are they same. Maybe see if a tap in the thread cleans it up
I did mean the thread where the brake line goes into the caliper.
Anyone knows what thread tap should i use? threads don't look dirty honestly...
I'm starting to suspect the previous owner tapped the calipers to a different thread since no one encountered such a problem.
Edited by alonroz
