Those relays control all the ACC and IGN circuits that run through the fuse box, they are triggered by the key turning.
Is there some problem you are trying to track down?
BTW everything there looks super neat, clean and unmolested....nice buy!
Thanks!  I got lucky, my car was an unmolested one owner car in Japan for 24 years, which is rare by R32 standards.
I am just trying to find the turn indicator relay.  Bought some Sylvania Zevo LEDs, but I don't want to splice in resistors.
The turn flasher is on the left of the steering column near the clutch, its a black box with an orange (from memory) mount.
If it's no longer right hand drive, it could be anywhere! But it's not part of the fuse box on a 32
Thank you for the info!  My car is still all factory so I am positive the relay is at its original location.
Turn indicators on and feel for the one clicking on and off. Thats how i found mine
All my lights (except headlights) are LED. Just bought a non load dependant flasher and wired it in for the indicators. Works a treat
Found a 9 year old post on GTR UK forum - the indicator relay is a black box with a white label on it under the steering column.  A picture was provided, but it no longer loads with the post being so old.
Which specific relays did you get?  I see some fairly cheap LED relays on eBay shaped like factory relay, so supposedly they are plug and play, no wiring needed.
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
