Removing battery from my R33
Hey guys, I'm trying to remove the battery from the rear of my R33 and for the life of me I just can't - the stud that the nuts are screwed on are too long for me to stick anything in there and the screw itself is too pushed in for me to get in there comfortably.
I just hate it how the battery is in the rear any ideas guys? Much appreciated.
Cheers,
Alex
https://www.sau.com.au/forums/topic/468910-removing-battery-from-my-r33/
Use a 10mm deep impact socket to get on the nuts or a spanner and it will work. Remove black cable (negative) first and leave it hanging somewhere out of the way before removing the red cable off the positive terminal. It should be clear but don't earth yourself or an object between the two accidentally either or you'll get a nice surprise. Once that is complete it's just a matter of pulling the battery out.
Easy as, I agree CAL.  however I do recommend you avoid acid spills/fumes and spend the extra and only use total seal batteries.
Look at Robocops photo's and the white powder...........that ain't snow!!!
    • I’m here solo don’t have any hands to help so haven’t hit it with a timing light
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
