SOLD
1996 R33 Skyline Gts-t - manual, 250rwkw
Hey guys, it's finally time to part ways with my '96 R33 Gts-t. I've owned it for about 4 years now, just upgraded so this has to go!
I originally bought it in 2013 with about 112,000 on the clock, now has approx 146,000, rego till end of June 2017. I'm after $11,900. Located at Kogarah in Sydney
When i first bought this it came with a high-flowed R34 OP6 turbo, I wanted something more responsive so I got a brand new Hypergear SS1PU turbo about 6 months later - installed it & got the car retuned. It's always been great to drive, boost comes on early and hard, fullboost (18psi) around 3500-3750rpm in 4th. Dyno graph was a hair under 250rwkw in a stuffy dyno room. Next step would be to slap in some larger injectors + larger fuel pump and run E85 for something closer to 300rwkw
Serviced regularly and always taken care with it, it's always been a great reliable car. Handles great, sounds great, it's got lots of induction noise & gear changes sound very noice
I've also got a huge pile of receipts and stuff for the car + dyno sheet, spare ECUtalk cable
Mod list:
Nistuned z32 ECU (tuned by Toshi from SAU)
Greddy profec B Electronic boost controller
JJR bellmouth stainless dump/front pipe
Ecutalk consult port display (displays RPM, load, fuel economy, various engine/temp sensors + many many more functions)
Fujitsubo catback exhaust - twin tip, good sound, not droney
80mm metal turbo intake pipe
Z32 AFM with Tomei plug
JJR coilpacks
Apexi pod filter
Blitz return flow FMIC (painted black)
Turbosmart recirc BOV
Nismo 555cc injectors
Nismo intank fuel pump (wired for alternator voltage through a relay)
Jim Berry full monty carbotic clutch
BC racing br coilovers
Front & rear Whiteline adjustable sway bars
Whiteline subframe pineapples
Nismo front strut brace with master cylinder stopper
Nissan rear strut brace
Tomei hicas lock bar kit
18" Speedy wheels, Hancook Optimo rubber all round - heaps of tread left
Nismo gear knob
Boost gauge
Genuine Nissan floormats
Pioneer headunit with bluetooth, USB, AUX input
12" MTX subwoofer, 6" Response splits up front - both wired to 4-channel amp in the boot
Windscreen replaced approx 1 year ago due to stone chip
Radiator (reconditioned by NATRAD) & Century battery approx 2 years old
The bad:
Driver's side window has a small scratch in the tint
Tacho usually jumps around (common R33 problem)
Small paint chip on front left edge of bumper from when a Taxi nudged me in a parking lot @ 5km/hour
Not interested in swaps or lowball offers - if you have 6k to spend look elsewhere
PM me if you're interested!
Pull your gauge cluster out and reflow(melt) the solder on all the circuit joints on the back of the tachometer. Worked perfectly for mine a few years ago and hasn't played up since.
  • Like 1
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
