SOLD
1996 R33 Skyline Gts-t - manual, 250rwkw
Hey guys, it's finally time to part ways with my '96 R33 Gts-t. I've owned it for about 4 years now, just upgraded so this has to go!
I originally bought it in 2013 with about 112,000 on the clock, now has approx 146,000, rego till end of June 2017. I'm after $11,900. Located at Kogarah in Sydney
When i first bought this it came with a high-flowed R34 OP6 turbo, I wanted something more responsive so I got a brand new Hypergear SS1PU turbo about 6 months later - installed it & got the car retuned. It's always been great to drive, boost comes on early and hard, fullboost (18psi) around 3500-3750rpm in 4th. Dyno graph was a hair under 250rwkw in a stuffy dyno room. Next step would be to slap in some larger injectors + larger fuel pump and run E85 for something closer to 300rwkw
Serviced regularly and always taken care with it, it's always been a great reliable car. Handles great, sounds great, it's got lots of induction noise & gear changes sound very noice
I've also got a huge pile of receipts and stuff for the car + dyno sheet, spare ECUtalk cable
Mod list:
Nistuned z32 ECU (tuned by Toshi from SAU)
Greddy profec B Electronic boost controller
JJR bellmouth stainless dump/front pipe
Ecutalk consult port display (displays RPM, load, fuel economy, various engine/temp sensors + many many more functions)
Fujitsubo catback exhaust - twin tip, good sound, not droney
80mm metal turbo intake pipe
Z32 AFM with Tomei plug
JJR coilpacks
Apexi pod filter
Blitz return flow FMIC (painted black)
Turbosmart recirc BOV
Nismo 555cc injectors
Nismo intank fuel pump (wired for alternator voltage through a relay)
Jim Berry full monty carbotic clutch
BC racing br coilovers
Front & rear Whiteline adjustable sway bars
Whiteline subframe pineapples
Nismo front strut brace with master cylinder stopper
Nissan rear strut brace
Tomei hicas lock bar kit
18" Speedy wheels, Hancook Optimo rubber all round - heaps of tread left
Nismo gear knob
Boost gauge
Genuine Nissan floormats
Pioneer headunit with bluetooth, USB, AUX input
12" MTX subwoofer, 6" Response splits up front - both wired to 4-channel amp in the boot
Windscreen replaced approx 1 year ago due to stone chip
Radiator (reconditioned by NATRAD) & Century battery approx 2 years old
The bad:
Driver's side window has a small scratch in the tint
Tacho usually jumps around (common R33 problem)
Small paint chip on front left edge of bumper from when a Taxi nudged me in a parking lot @ 5km/hour
Not interested in swaps or lowball offers - if you have 6k to spend look elsewhere
PM me if you're interested!
Pull your gauge cluster out and reflow(melt) the solder on all the circuit joints on the back of the tachometer. Worked perfectly for mine a few years ago and hasn't played up since.
  • Like 1
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
