9 hours ago, MatthewT85 said:
It's interesting seeing your results. I have atr43ss2 with a cooling pro return flow and the first time I had it tuned it made about 280. Not long after getting it back it started knocking coming on boost. Took it back and 4 degrees of timing was taken out to keep it safe. Bringing it back to 250ish. Apparently it just couldn't take sensible timing and had high IAT. Wondering if it's same issues.
Also i had a gasket fail too, but it was the manifold one, was some cheap shit one and studs were finger tight
From all the threads I have read, it seems return flow is not ideal for trying to get past 250rwkw on 98.
They just aren't efficient enough. Plenty of people have made more power but it's normally with bigger turbos and better setups.
Tuner didn't mention anything about high IAT or timing issues on mine, it seemed though to have pressure drop across the intercooler.
Post intercooler it would hit 20psi and bleed down to 16psi, pre intercooler it would hit 20psi and hold around 19psi.
Enjoy the 250rwkw though and if you feel like chasing down the issue then do that once the 250 gets boring, that's what I'm doing :)
yeah i have noticed that too about 250 being the average.  Just weird that I had 280 at one point, although tuner did find the gate slightly open and once that was tightened maybe it didnt like it... but didnt show up at the time.
The only thing I can see different on your graph is mine has boost around 16psi and slowly rises to 19-20ish at redline, in my other thread people have mentioned things like CAS so I guess I just have to work out what I want to start with...
Well having 280 at one point makes the 250 boring straight away :(
  • 1 month later...
Currently have a weird grinding noise between 1000-2000rpm coming from the front of the engine around the CAS/Cylinder 1
Going to try get the CAS off over the next few days and work out if that's what's causing it.
Video of the grinding noise if anyone is interested in hearing it.
The video is just there for the sound, not for the actual footage.
Had a few people comment on it being potato footage, the intent was just to get the noise not footage of the front of a normal RB25neo...
Also have a loud fuel pump, so might pull that out and try cut a bit off the bracket and install another clamp on there.
Hopefully that will stop the buzzing that it currently has.
Did you change your timing belt when I changed mine the idler made it whine like that.
I'd be pretty confident in saying that you are running a gates racing timing belt? They usually make that sound for the first couple thousand kms. The noise from the belt will go away after running in. It's also quite possible that your timing belt may be a touch to tight.
Hey mate, thanks for the info.
I'm actually running just a genuine timing belt.
Someone actually presumed the same thing when they heard the noise so maybe it is a touch too tight and makes it sound like the gates do.
I purposely didn't get a gates because I saw so many posts about them being loud.
  • Like 1
I was half right with my answer then haha. Easy fix.
  • 2 years later...
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
