Nice work. I thought about making something similar for the power windows after having to dismantle the switches and clean the deposits off all the little individual copper rocker arms and contacts.
It's crazy to think that 20 years ago, all of those little components of the switch were  the cheapest way to manufacture a power window switch.
But if that arduino assembly sits in the door panel, I'd be concerned about moisture and corrosion. It's essentially an outdoor area, electrically speaking.
Clutch replacement time!
Parts:
Nismo Super Coppermix Competition Twin Plate Clutch (3002B-RR598-C),  comes with clutch release bearing (30502-12U00), Nismo clutch fork boot (30542-12U00), and flywheel bolts (not sure if there was a part number on them?)
Nismo braided clutch hose (46211-RS596), comes with copper washers (46237-A4600) and bleed nipple/clutch damper delete (41128-RS024)
Rear crank oil seal (12279-5L310)
Spigot bush (32202-B950A)
Nissan clutch fork boot (30542-12U00), didn't realise the clutch comes with one
Random clutch alignment tool found on eBay
Edited by jimnastic
The plastic on the under side of my drivers switch actually completely fell apart, which is what led me down this path of various window switches. Wasn't going to pay $600(!) for a new one from Nissan, and I didn't trust a used one to not have the same problem. I was even thinking of getting a replacement 3D printed, but I figured it probably wouldn't be a perfect match, and it seems to just be an inherently flawed design with the way the spring inside the button is forced at an angle every time you use it.
Good point about the corrosion, I hadn't even thought of that. I was going to fit the whole thing in some kind of plastic enclosure when it's done, but I guess if it fails, the parts I've used aren't very expensive to replace
It took three trolley jacks and creative use of a garage creeper, but I managed to get the gearbox out. Attempts were made to clean it, mustn't have looked much better after cleaning because I didn't get any pictures
Removing the old clutch reveals a sad looking flywheel. Further creative use of tools with a 12mm spanner being used to stop the flywheel from turning when removing the flywheel bolts
New vs old
New crank seal in. Oil seems to just be left over from a leaking cam cover seal a while back, nothing to worry about
New flywheel and spigot. Managed to get the spigot bush out by inserting an appropriately sized socket and sort of wiggling and rotating it out. Flywheel bolts torqued as specified in instructions for the clutch
Clutch is in
  • Like 1
2 hours ago, jimnastic said:
Haha similar situation with the wife's Polo. Will take crappy switches and RB soundtrack any day
Also been thinking of doing something to replace the awful headlight/key buzzer sound with that nice VW 'ding ding ding'. Maybe it would be easier to just swap the RB into the VW at this rate
LOL... get a nice S3, then RB swap it..
no more check engine light LOL
  • Like 1
The gearbox put up a fight, but I managed to persuade it back in (no pictures as there's not much to see). The new clutch made a huge difference, made me realise how bad the old one actually was, and the car now feels a bit quicker too as I suspect the clutch was slipping more than I thought.
As mentioned in an earlier post, the one and only time I've had work done to the car by a mechanic was when I had the previous clutch installed in around 2013, and I was quite annoyed when I realised a few months after that he hadn't reinstalled the exhaust mount that hangs off the gearbox, so I replaced these while I was at it
Rubber mount 20610-24U00
Metal bracket 20711-04U11
Finally got around to cutting the coil cover to fit as well. The engine cover paint is looking a bit rough, will be redoing that some time
Installed the rear camber arms (PN 8628 from Hardrace), along with a set of camber lockout bolts from GKTech to replace the standard eccentric camber adjustment bolts. Forgot to get pictures, but the process wasn't very involved, just wheels off and undo a couple of bolts.
The drivers side seatbelt has never fully retracted properly, so I remove the seatbelt and cleaned it in some soapy water. This picture is after the third time I changed the water, absolutely filthy. While cleaning it didn't completely fix the problem, I'd say it probably made it about 50% better
I got a bit carried away while doing the seatbelts and ended up stripping out the interior for a big cleanup
Before
After
I also removed the drivers side and rear seats for the same treatment. It's all looking pretty spotless now, until everything gets covered in filth again
Edited by jimnastic
  • Like 2
That brings everything up to date again. On the to do list at the moment, I need to get the new headlight lenses installed, finish up my little window switch side project, and I'm considering fully removing the stereo system. I actually can't remember the last time I even had the stereo turned on, and the OEM stereo I want to install would need to be modified for Aus FM frequencies, so I could save myself a lot of trouble and just rip the whole lot out to save some weight. I'll still have the OEM stereo installed, but only for looks.
The GT-R hasn't been on daily duties as of around a year ago, as I now have a work car, so I guess the title of this thread is no longer accurate, but fortunately that means I can get a lot more done to it as I don't need to make sure it's always put together and ready to drive.
Longer term, I'd like to get the tune touched up now that the clutch and ignition system are dealt with, but I'll also be looking into what else I can do for a bit more power, then get one final tune done and leave it at that. Will try to keep this up to date as things happen.
  • Like 1
Today I pulled the headlights out and got started on replacing the lenses. Nearly have one of them done, just need to stick it back together. Not particularly difficult to do, but it does require a lot of patience to get the old lens off. The biggest issue I had was static that made the new lens a dust magnet, which resulted in some tiny scratches on the inside of the lens from trying to clean it out. Nothing too noticeable unless you look super close, but still annoying
Here are some comparison photos, hard to get a good picture, but they look great in person
And just a quick photo comparing the standard GT-R stereo vs the Micra one, they're almost identical. I want to at least add a 5V USB output for a phone charger and to power the dash cam, but I'll also see if I can get the boost controller to fit in like I've done with the current JVC unit
  • Like 3
  • 3 weeks later...
On 8/25/2018 at 1:37 PM, JGTC said:
Wrapping the headlights is a genius idea, spotless carpet and factory looking radio are fantastic.
Thanks! Happy that people seem to enjoy the focus on all of these minor bits and pieces
  • 6 months later...
On 4/3/2019 at 12:23 PM, Figjam Jimmus said:
Any more updates??
Probably about time for an update. Here's a couple of pics to get started
September 2018 - Changed the absolutely shagged hicas ball joints (part # 55154-30P01)
Started repainting the engine covers. Did this the same way as last time (VHT anodised base coat + red top coat), just with more coats of red. Came out a lot better this time
8 hours ago, jmknights93 said:
Those covers painted with the anodised red or the engine enamel red?
4-5 coats of anodised red, with a clear coat as well. I probably went a bit overboard with the red coats, but I didn't want it to fade again like it did before
  • Like 1
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
