Tomei 264/264 8,5 poncams
Hi i just bought tomei poncams with 264/264 8,5 lift to My rb25det spec 1 nvcs with lash type/hydraulic lifters. I have installed tomei type a springs too.
But The problem is The car missfire and everything. When i checked comp on cylinders some have VERY Liw like 4-5 bar and some 11 bar.
Then when i installed The oem intake camshaft i had normal comp in all cylinders with 264 exhaust CAM left in engine.
Camwhells are oem.
This CAMs are dropins says tomei.
Anyone that knows or have seen problem like this?
https://www.sau.com.au/forums/topic/469626-tomei-264264-85-poncams/
24 minutes ago, KiwiRS4T said:
Are there different cams for VCT and non VCT engines (i.e do you have the right ones)?
Yes and i have vct on My engine and those CAMs are compatible. According to The seller is nvcs ANd vct The same?
Edited by M3flatout
10 hours ago, tridentt150v said:
Adjustable cam pulleys, if yr using STD pulleys then u can't adjust. If yr using eg Romeo's with a live centre then they should be zero.
I dont have adjustable camwheels. Allt stock wheels. Well The vct wheel is adjustable tho. But i tried to back IT and foreard IT with VERY Lottie changes. But not enough
If its fine with the OEM inlet cam and not with the Tomei look very hard at the Tomei for damage - preferably with old and new side by side. Is the CAS drive piece the same on both (and undamaged)? See if uou can find numbers on the cam to confirm that they are a pair. can you install the cam 180 degrees out? If the Tomei Inlet cam is putting your compressions  miles out something is very wrong.
The CAms knocks looks like The same. The cas drive is on The exhaust side. I have tried to fully retard and advance The oem vct cam gear with VERY little changes on compretion. Numbers on CAMs are a2685x on The exhaust and b2685 on The intake side.
    • I've got a 2011 J50 that I imported six years ago. The unmodified factory AV system date and time has always been correct ( Japanese timezone of course ) up until last month. About two weeks ago, at engine start, the system wished me a happy new year ( in Japanese of course ). I can't think of anything that would make the system think that the date had changed, unless the GPS component has failed/reset somehow ? I checked the GPS reception in the system settings, and it can still see the satellites. Has any other J50 owner had this happen ?  It's no biggie, just annoying that it tells me the wrong date anytime I start the engine. 😅
    • Love following your adventures on IG, hopefully if you're still around in Japan when we visit again wouldn't mind going for a few beers with you (that's if you're keen on hearing how I hate Nissans).
