Spacers
Consensus on running a small 3mm slip on hub centric spacer to gain some clearance to the shock tower to allow a little more camber?
Stock S13 wheel nuts, haven't measured thread engagement just yet.
4 stud car so finding wheels is painful.
https://www.sau.com.au/forums/topic/469977-spacers/
I looked at using those, smallest was 10mm though so I thought I'd end up with guard clearance issues, plus then the front track will be wider than the rear, by default the rear is wider, and in my case wider again as it has the S14 rear subframe.
https://www.sau.com.au/forums/topic/469977-spacers/#findComment-7823488
Checked threads, not comfortable running spacer on those.
Given how hard it is to find a square set of 4 stud 17x9, any issue with running 10mm bolt on spacers only at the front? Would mean front track was wider than rear, which is not standard.
Or could  just run them all round, keep track even and make car wider.
https://www.sau.com.au/forums/topic/469977-spacers/#findComment-7824770
Or another idea.
Could use hub centric 15mm or 20mm 4 stud bolt on spacer and then be able run the rear 17x9 rim i have from the other set of the same rims on the front so I can get 255 on it all round).
Seems there's plenty of guys on there using proper hub centric bolt on spacers, it;s non hub centric and slip on people don;t like.
https://www.sau.com.au/forums/topic/469977-spacers/#findComment-7824779
  • 4 weeks later...
I would say no, if the car has even track width side to side there should be no impact on HICAS, maybe the rack works a touch harder as the wheel has been moved further away from the axis of pivot.
Get your rear alignment checked and inspect the HICAS tie rod ends for wear and play of you want to keep it in, otherwise, Lock it out but do it properly where you press the tie rod ends out.
https://www.sau.com.au/forums/topic/469977-spacers/#findComment-7830628
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
