Spacers
Consensus on running a small 3mm slip on hub centric spacer to gain some clearance to the shock tower to allow a little more camber?
Stock S13 wheel nuts, haven't measured thread engagement just yet.
4 stud car so finding wheels is painful.
https://www.sau.com.au/forums/topic/469977-spacers/
I looked at using those, smallest was 10mm though so I thought I'd end up with guard clearance issues, plus then the front track will be wider than the rear, by default the rear is wider, and in my case wider again as it has the S14 rear subframe.
https://www.sau.com.au/forums/topic/469977-spacers/#findComment-7823488
Checked threads, not comfortable running spacer on those.
Given how hard it is to find a square set of 4 stud 17x9, any issue with running 10mm bolt on spacers only at the front? Would mean front track was wider than rear, which is not standard.
Or could  just run them all round, keep track even and make car wider.
https://www.sau.com.au/forums/topic/469977-spacers/#findComment-7824770
Or another idea.
Could use hub centric 15mm or 20mm 4 stud bolt on spacer and then be able run the rear 17x9 rim i have from the other set of the same rims on the front so I can get 255 on it all round).
Seems there's plenty of guys on there using proper hub centric bolt on spacers, it;s non hub centric and slip on people don;t like.
https://www.sau.com.au/forums/topic/469977-spacers/#findComment-7824779
  • 4 weeks later...
I would say no, if the car has even track width side to side there should be no impact on HICAS, maybe the rack works a touch harder as the wheel has been moved further away from the axis of pivot.
Get your rear alignment checked and inspect the HICAS tie rod ends for wear and play of you want to keep it in, otherwise, Lock it out but do it properly where you press the tie rod ends out.
https://www.sau.com.au/forums/topic/469977-spacers/#findComment-7830628
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
    • There's not a great deal to report here .... except ...... FOR .... LSD!!!  I bought a Quaife LSD from the UK and shipped it here .... Wish I'd just bought locally cause the shipping and duty was $700! But there were so many diffs used in the E90s I just wanted to be absolutely certain I was getting the right one so I spoke with a supplier in the UK who builds race cars and they have heaps of experience with the E90s.  I pulled the diff out which was seriously awesome - I've never done anything like that before, I must have watched 1000 videos on YT about it as well as consulting the Bentley manual. It was super easy in the end. The diff was delivered to the awesome folks at Hornsby Diffs and will be back in a few weeks. I also replaced the diff bushings with some Nolathane ones.  Really looking forward to getting it back and getting back to the track or even the skidpan.
    • yeah... the 13kg/mm springs weren't always in there, I had 10kg/mm but doing a few SMSP commanded heavier front springs. It's so good now going into T1 and T2, just need more seat time and real tyres.
