Brake pads for Skyline V36 sedan
Ive spent a few days on here trying to work out part numbers and what pads to get for our 2007 Skyline v36 sedan type S.
I thought this would be simples as the type S and the SP have bigger brakes than the type P, but there are different types of model numbers and different info out on the net...
Any advice or info ?
Ive attached a few pics, I didn't really want the hassle of jacking the car up, pulling the pads out to take photos of them and then putting them back in with the old pads. First photo is front, other two is rear
Edited by R377
dfdff
https://www.sau.com.au/forums/topic/470009-brake-pads-for-skyline-v36-sedan/
6 minutes ago, The Max said:
Those calipers don't look like a type S at all. Then again, my knowledge of anything pre-2009 is very limited.
some websites say 06-08, then 09-onwards are different
Some sites say V35 non brembo and v36 pads are the same.
Some say suit most PV36 and some KV36.
All very confusing
The early sedan's have large single pot front calipers running a 330x32mm rather than the expected twin pot caliper on a 320x28mm disc.
This means different front discs and pads.
The rear discs are also different sizes, bigger on the old cars, but seem to be the same pads... I have attached some data from the Infiniti service manuals.
Give Brakes Direct a call, they have pads for both fronts, but currently only the smaller front discs.
  • Like 1
I just bought some for my Coupe today.
I found this thread which i used to find some
Fingers crossed they fit my my car.
I've had trouble finding the right ones.
Coupe
Sedan
Sports
Sports Premium
Brembo
  • Like 1
3 hours ago, nickcorr said:
No Brembo's on a V36.....
However, depending on which year model, can often be confused with the 370Z, which is specified to have Brembo. For example, the DBA 4000-series discs I bought for my 2009 V36 are tagged as being suitable for the Brembo-equipped 370Z.
With all these terms being thrown about, it's no wonder people get confused. I can appreciate that.
Safest thing I would suggest to Mr. R377 is to measure those discs and use that as a point of reference for which pad he needs. That's how I determined mine. Measured, looked them up in the workshop manual and then ran from there.
  • Like 1
Thanks for that link - those pads look the same as mine.  Maybe the 2006 and 2007 brakes are different to the 2008 brake pads.  It makes it hard looking online in australia as soon as I put in 2007 skyline, it automatically selects the V35 and not the V36 skyline.
Here are pics of my pads and brakes.  Discs / rotors are 330mm by 32mm thick.
For reference our car is 2007 Skyline type S. From what i believe it is an type S as it has cloth interior, no reversing camera/sat nav, has the bigger brakes with the 18" wheels.
The type S and SP share the same bigger brakes with the 18 inch wheels.  The type P has smaller brakes with 17" wheels.  The type P has the all leather interior and BOSE stereo I think ? I think maybe the suspension is different on the type P vs the type S and type SP. The P and SP both have leather interior with heated seats, while the S gets the cloth interior.
On 13/04/2017 at 9:58 PM, qdhung said:
i got bendix pad for rear , but the front took me awhile so end up with ebc red. check my image for info
Thanks for the info Hung, those EBC reds look the same as mine.  Have you got any photos of the actual pads out of the box ? (just so i can be 100% sure before ordering)  Where did you buy the EBC from please ?
I forgot to add, the pads are from Intima brakes, a few guys on this forum run Intima brake pads.
From what I have seen the 1509 rear brake pads are quite common and universal, the main problem us Skyline owners have is getting the front pads correct.  I don't know if the front pads listed from Intima are for a coupe, or 2008 onwards sedan, or even a type P sedan ?
Sorry im not sure exact figures all i remember it took me awhile to get the corrected pads :)
also i got pad from shop called BGT in victoria
Edited by qdhung
more info
  • Like 1
  • 3 weeks later...
Thanks qdhung for the info.  I thought i would just double check with EBC directly
Those front EBC brake pads are DP31807C
The front rotors are D7459 (RK7459 in USA)  from EBC
From what i think the brakes from v36 sedan 2006 to late 2008 are what me and qdhung have, I think in late 2008 the v36 skyline sedan then went to the 3.7L with 7 spd auto.  I am guessing they changed the brakes then to the Akebono  calipers ?
These are the two brakes that were fitted on the V36 sedans from factory. The 3.5 and earlier 3.7 to at least 2009 MY (my car) run the 330 mm disc and single piston calipers. The later cars, maybe from 2010 when they had the facelift and proper foglights, got the 320 mm disc and 2 piston calipers.
No Akebonos from factory on the V36 sedans.
  • Like 1
    • Yep, it was only an option on the Q50 Hybrid.  Same in Japan as far as I know. And doesn't use a centre diff like the Suby's do, so not the same as the WRX.  But it also isn't a reactive AWD like other Nissan AWD vehicles are, eg. Murano/Xtrail/etc.
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
    • That's one of the reasons I got that breed, they look weird, the other reasons are they small, they are very vocal, and run around like they are on crack, I didn't want a breed that just sits around, these two are like kids on red cordial  My daughter has one, and it's a laugh riot, constantly doing Parkour around the house, sits on her shoulder, plays catch, and constantly runs around the house taking turns chasing the dog around, her Bermese though, just lays around with constant bitch face, and just looks on in utter disgust at the cat and dog playing together
    • I'm getting PTSD flashbacks seeing that name again.  With my turbo swift, I got 1,500km of street use on a Jim Berry clutch before it exploded and took out my input shaft with it.
