2006 250GT Aux/16 pin connector
Hey guys,
I've been using my bluetooth for music in my 2006 Skyline 250GT for months now and I'm finally over the cutting out issues, so I've taken apart my center console and had a look and see why there is no cables coming through the 3 holes used to red/yellow/white cables.
I know absolutely nothing about these sorts of things but as per photos, the 3 plugs were plugged into some box with foam glued around it under the center console (so I couldn't see what it was) I'm hoping it's plugged into the massive (I think 16 pin) connector (refer to photos again)
So my question is - Am I able to find a connector somewhere that turns that 16 pin connection into an aux/something for my iPhone to play music? Or am I going to have to resort going to an auto electrician so they can connect an aux.
Thanks so much for the help in advance.
Cheers,
Rupert.
https://www.sau.com.au/forums/topic/470027-2006-250gt-aux16-pin-connector/
The previous owner has installed an aftermarket device that connects your phone's screen mirroring to the auxiliary input of your system. The dodgy bastard has removed the AUX RCA connectors in your console in an effort to internalise all the cabling.
That solves the mystery of the three empty holes.
  • 3 months later...
On 7/21/2017 at 3:53 AM, acesofspades31 said:
Hey guys,
Same issue here, can't seem to find a way to get the mirabox installed. Any luck Huskian?
Hey dude,
Nah no luck so far aye.
I'm probably going to have to end up going to an Auto Electrician. :(
Hey dude,
I'm probably going to have to end up going to an Auto Electrician. [emoji20]
I've gotten in touch with sinergy motor sports from SA and they have a RCA Harness that may work but from what I've researched it plugs in the back of the head unit.
Please see the link below
http://www.sinergymotorsports.com.au/cart/products-page/nissan-skyline-v36/video-rca-input-cable-harness/
Again, I'm not 100% sure if this will work but I'm still researching on it and nobody from sinergy has gotten back to me. May be you can show it to the auto electrician and see if it works. I would strongly recommend to get a professional opinion before you order a $100 cable.
I think that cable is only for vehicles that already have a factory Nissan Japan TV set up. Is it to add RCA inputs into the TV tuner, and I think is mainly for M35 Stagea and V35 Skylines. As far as I am aware, all V36 models with and without Nav, have RCA connectors in the arm rest. If they are not there, then someone has opened up the armrest and repurposed them for some other input to the factory display screen.
Pretty certain that when I had it all apart to fit my cruise control and tv screen on all the time cable, there were no spare inputs on the back of the head unit.
Hey dude,
Hey mate,
I just got RCA Inputs done at carstereo.com.au in Perth. Not too sure where you're at but it costed me about $110 for everything.
If you're in WA, hit them up.
  • 2 years later...
Unsure if related but going to post here as well
Yo if anyone is still looking into this. This blue box pops up when Bluetooth drops. I think it's to do with carvings attempting to connect to the radio towers in Japan and failing.
I set a setting to only connect when the car starts.
Go to carwings
Option 1 (information channel setting)
Option 1 (automatic time setting)
Option 3 (when engine starts)
Doesn't do it anymore and it was doing it every 5minutes (what the previous setting was to talk to radio towers.)
Happy uninterrupted Bluetooth Y'all!!
  • 3 months later...
Hey guys,
Cheers,
Rupert.
I’m trying to connect my phone for Bluetooth only calls connect mine is 2007 250gt how did I connect Bluetoothmusic
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
