Brake Lights Staying On
Brake lights staying on !!
Hi all
Just noticed my brake lights and wing light are stying on . Took it for a short drive then put it on stands to see if it brakes ok .It does. Checked all the fuses all fine . Took the battery off.
Any suggestion / ideas would be much appreciated
Cheers
Bruce
https://www.sau.com.au/forums/topic/470112-brake-lights-staying-on/
They are controlled by a small, adjustable switch at the brake pedal.
First unplug the switch at the pedal and make sure the light goes off.  Assuming it does, push the switch a few times and see if it frees up, and if not it can be adjusted a little.  Otherwise it may just have failed and need replacing.
Yes it was the switch thank you.
Also found rubber/plastic button like bits on carpet which, I assume hits the switch ???
Seen the whole brake switch on Super cheap Auto would they fit ? or just find the rubbery end bit?
Thanks
I'm not near the car to check, but this is the service manual page for it
It looks like a similar setup to my navara where the rubber stopper disintegrated a few years back leaving nothing for the switch to turn off against. Pretty sure I picked up the part at nissan for a few bucks after my dodgy fix failed again.
This has happened to me in every import I've owned.
When that rubber piece brakes, I just super glue a five cent piece over the ensuing hole. Otherwise that switch doesn't get depressed when you let the brake off.
  • 1 year later...
gotta love SAU!
My brake lights were on when I came home yesterday - figured it was most likely the switch, but did a search on SAU and bingo!
Even found the bits on the carpet, but wow it's tight under there :( - a quick look last night and another this morning, I was able to push the button in to prove the fault, but didn't have time to try an maneuver a 5c piece or similar in to activate the switch, or disconnect the connector...so the brake lights stayed on - got home tonight and the bulbs are blown - I should have disconnected them at the tail lights in the boot!
Not surprising in hindsight - cautionary tale - of course brake lights won't cop being on for 24hrs - they burn bright when required but aren't designed to stay on. At the time I was more concerned with flattening the battery, so had the battery charger on.
No biggy, bulbs are cheap...
I'm more concerned with the contortionist activity required under the dash to fix the switch - likely I'll have to remove the driver's seat to give me more room...
The glued 5c piece option sounds dodgy, but actually looks the best solution compared to swapping the switch assembly including disconnecting/reconnecting the connector...getting to it is tricky - admittedly I was holding a torch in one hand, so a fixed light source and 2 hands would help.
Is the rubber grommet piece available as a spare part - preferably without buying the whole switch? Pushing a new grommet in looks even easier than the glued 5c piece (not that anything is easy under the dash :( )
I'm wary of doing any mods to the braking system (or in this case the brake light system) - am I being too paranoid or appropriately cautious?
The car is not a daily and can stay off the road for a bit.
cheers
Mike
thanks goes to @Duncan for the diagram so I could get the clearance right when re-installing the switch, and @Dose Pipe Sutututu and @duffmansbrew for where to get the replacement bit ?
Biatch of a job under there - removing the switch makes it "easier".
I used a smidge of silicon grease on the hole to help the rubber bit slip in, and a flat blade screwdriver for a bit of leverage - it doesn't need force, it's just in an awkward spot.
Thanks again SAU!
cheers
Mike
  • Like 3
  • 1 year later...
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
