Rb25 det running poorly - coil related?
not sure if related to the coil or dirty plugs but my rb25 seems to run with a struggle in low rev range. The rev range is not smooth and feels like its spitting.
It has 5 red jacket coils and 1 standard coil which the previous owner diagnosed as the cause of the issue.
Im in the process of removing plugs and just needed a confirm from others who have had this issue resolved.
is it the odd coil, dirty plugs, or both?
Thanks
Edited by AARR34
Could be anything but borrow a known good set of coils to confirm. I would only use genuine OEM coils or Splifires. Pull the plugs while the coils are out and if they are not in good cond get a new set gapped to 0.8mm
  • Like 1
Is the problem noticeable at idle?
If so, pull coilpack plugs one at a time while idling. Listen for a note change as you pull the plug. If there is no note change or a less pronounced note change one one, then chances are that is your dud coil (if that is indeed the problem)
  • Like 1
yeah it happens in idle and gets less noticeable as the revs climb.
I just hope its nothing major to do with the motor. I'm getting new plugs to go in with the coils. The owner had mixed plugs and 3 of them require a larger socket to take out.
I don't get why people do that
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
