Don't want to spend to much maybe the 10k mark and would use a couple times a week and need the set up to be reliable and don't care about engineer cert. As I have never in the 8 years owning the car had cops look under the hood
https://www.sau.com.au/forums/topic/471039-slick/#findComment-7837359
Every engine you've listed will probably cost more than $10k to rebuild and install in an S15, think wiring, clutch, ecu, fabrication etc etc.
Why do you want an engine conversion, what are you doing with the car? A built SR20 will be both legal(enough) and will be a great match for the car.
https://www.sau.com.au/forums/topic/471039-slick/#findComment-7837406
I used to have a vl turbo and just loved the sound and the performance of it but the cops picked on me non stop so ended saleing it, the SR I want to keep aside as a original for one day. All the fabrication I will do my self as I'm pretty handy the only thing that I'm gonna have a problem with is the wiring but will sort it out, to have a 6 in it would be awesome the sound gives me goosebumps
https://www.sau.com.au/forums/topic/471039-slick/#findComment-7837407
RB25 now we're talking but one thing I don't know is can I use r33 k frame and g-box mount so I don't have to use after market mounts?? To save a little bit of cash there, thats all I'm stuck on If I'm going to do this...
https://www.sau.com.au/forums/topic/471039-slick/#findComment-7837576
Bullshit thats all you are stuck on !!! :D
https://www.sau.com.au/forums/topic/471039-slick/#findComment-7837582
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
