Don't want to spend to much maybe the 10k mark and would use a couple times a week and need the set up to be reliable and don't care about engineer cert. As I have never in the 8 years owning the car had cops look under the hood
https://www.sau.com.au/forums/topic/471039-slick/#findComment-7837359
Every engine you've listed will probably cost more than $10k to rebuild and install in an S15, think wiring, clutch, ecu, fabrication etc etc.
Why do you want an engine conversion, what are you doing with the car? A built SR20 will be both legal(enough) and will be a great match for the car.
https://www.sau.com.au/forums/topic/471039-slick/#findComment-7837406
I used to have a vl turbo and just loved the sound and the performance of it but the cops picked on me non stop so ended saleing it, the SR I want to keep aside as a original for one day. All the fabrication I will do my self as I'm pretty handy the only thing that I'm gonna have a problem with is the wiring but will sort it out, to have a 6 in it would be awesome the sound gives me goosebumps
https://www.sau.com.au/forums/topic/471039-slick/#findComment-7837407
RB25 now we're talking but one thing I don't know is can I use r33 k frame and g-box mount so I don't have to use after market mounts?? To save a little bit of cash there, thats all I'm stuck on If I'm going to do this...
https://www.sau.com.au/forums/topic/471039-slick/#findComment-7837576
Bullshit thats all you are stuck on !!! :D
https://www.sau.com.au/forums/topic/471039-slick/#findComment-7837582
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
