Opinions for Porting Factory Manifolds to Support Garrett -9s
My engine is out and while it's out, I'm pondering how much to port the factory exhaust manifolds.
I want good responding characteristics and reliability, and I don't care for top end output.  So I get the Garrett -9s and pair them with Tomei Poncam Type A and Tomei dumps.  My factory exhaust ports measured at 38mm x 41mm, and I know OEM N1s are 38mm x 47mm.
I am thinking just 2mm and make them 38mm x 43mm, so it doesn't lag too much at the low end.  I know this is perhaps unnecessary minutia, but I still appreciate your opinions!
I would, and I did.... just match the profile of the turbo, no more no less.
Would also recommend if you haven't already, ceramic coating the hotside from manifolds to front pipes while your there.
  • Like 1
Are you also running Garrett -9s?  If so, at what psi/bar are you running, and at what rpm does it reach full boost?
My car cam with Tomei Expreme manifolds, which I removed when I went to -9s and I used N1 manifolds instead as they are cast (so no risk of cracks) and slightly larger than the stock manifolds, but not as big as the Tomei's. Best of both worlds.
Don't port them for power, port them for response/smooth gas flow. As was said stock manifolds flow plenty for a -9 turbine housing.
Oh and if you want ultimate response get rid of the Tomei cams and get some cam gears only.
The best you will achieve with aftermarket off the shelf cams is almost matching response and better top end.
The only way you will get better response from a cam is a custom job with mad lift and no extra duration.
I have kelford L182A (with -9s, N1 manifolds, big dumps and exhaust and e85) and we basically matched response but with much more mid range and top end grunt.
I will also add, and this is an unpopular opinion, if you want response and are going to run the -9s at higher boost, get pods.
I gained 14rwkw and response was better moving away from the factory 34 airbox and apexi panel.
Just intake cam gear or both intake and exhaust cam gears?  And at what degree would you suggest?
Port matching is also being considered, as I'm curious if the exhaust air exits manifold into turbine housing would result in turbulence because of the different size.
Yeah I believe pods would give performance gain across range, but they are just a bit unsightly for me.  I did get the HKS panel filter though, unnecessary expensive for a flat piece of sponge. lol
Both gears and get them adjusted on the dyno. Usually it's a few degrees advanced on the intake and a few retarded on the exhaust.
Port matching is fine, just don't open the ports too much.
Get a pod box.
  • 4 weeks later...
I left the factory manifolds as they are.  But I'm still really struggling if I made the right decision...
How much of a top end loss should I expect without port matching?  And how much of a lag should I expect if I do?
Engine is still out waiting to get intake plenum back from powder coating, so there is still a chance to reverse course!
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
