Opinions for Porting Factory Manifolds to Support Garrett -9s
My engine is out and while it's out, I'm pondering how much to port the factory exhaust manifolds.
I want good responding characteristics and reliability, and I don't care for top end output.  So I get the Garrett -9s and pair them with Tomei Poncam Type A and Tomei dumps.  My factory exhaust ports measured at 38mm x 41mm, and I know OEM N1s are 38mm x 47mm.
I am thinking just 2mm and make them 38mm x 43mm, so it doesn't lag too much at the low end.  I know this is perhaps unnecessary minutia, but I still appreciate your opinions!
I would, and I did.... just match the profile of the turbo, no more no less.
Would also recommend if you haven't already, ceramic coating the hotside from manifolds to front pipes while your there.
  • Like 1
Are you also running Garrett -9s?  If so, at what psi/bar are you running, and at what rpm does it reach full boost?
My car cam with Tomei Expreme manifolds, which I removed when I went to -9s and I used N1 manifolds instead as they are cast (so no risk of cracks) and slightly larger than the stock manifolds, but not as big as the Tomei's. Best of both worlds.
Don't port them for power, port them for response/smooth gas flow. As was said stock manifolds flow plenty for a -9 turbine housing.
Oh and if you want ultimate response get rid of the Tomei cams and get some cam gears only.
The best you will achieve with aftermarket off the shelf cams is almost matching response and better top end.
The only way you will get better response from a cam is a custom job with mad lift and no extra duration.
I have kelford L182A (with -9s, N1 manifolds, big dumps and exhaust and e85) and we basically matched response but with much more mid range and top end grunt.
I will also add, and this is an unpopular opinion, if you want response and are going to run the -9s at higher boost, get pods.
I gained 14rwkw and response was better moving away from the factory 34 airbox and apexi panel.
Just intake cam gear or both intake and exhaust cam gears?  And at what degree would you suggest?
Port matching is also being considered, as I'm curious if the exhaust air exits manifold into turbine housing would result in turbulence because of the different size.
Yeah I believe pods would give performance gain across range, but they are just a bit unsightly for me.  I did get the HKS panel filter though, unnecessary expensive for a flat piece of sponge. lol
Both gears and get them adjusted on the dyno. Usually it's a few degrees advanced on the intake and a few retarded on the exhaust.
Port matching is fine, just don't open the ports too much.
Get a pod box.
  • 4 weeks later...
I left the factory manifolds as they are.  But I'm still really struggling if I made the right decision...
How much of a top end loss should I expect without port matching?  And how much of a lag should I expect if I do?
Engine is still out waiting to get intake plenum back from powder coating, so there is still a chance to reverse course!
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
