RB26 ECU questions
I have an RB26 which was assembled with technology current at the time when Noah was a boy.
It runs the following (On petrol because I cannot get E85 within 100 miles of home)
Bang up to the minute Power FC ECU.
Sard 700cc injectors.
Z32 AFM's.
Blitz dual solenoid boost controllers (Which actually works pretty well)
Various cams (256 inlet, 252 exhaust), turbos (-5's), cam gears and other things.
The car runs 20lb and makes an amount of powahs that can only be described as insufficient.
I have a thought that an ECU upgrade (not so much for the powah but to make the thing drive nicer, idle, etc etc and to be able to hook it into my data logger) may be in order and a Link G4 is on the list of likely options.
Are the injectors ok as I cant work out the impedence etc references and reconcile them with the ballast resistor blather RB20 types go on with.  Do I need to replace and/or fit anything to the injectors to work with the ECU?
Of the options available from Link are they worth the money?
Can anyone offer commentary on how they found the tuning experience/results with the ECU?
https://www.sau.com.au/forums/topic/471248-rb26-ecu-questions/
Link are not bad and there are plenty of other options on the market that are just as easy - Adaptronic and Haltec would be others to look into but really it comes down to who is tuning it and what they are comfortable with. Even having a top of the range Autronic / Motec unit will get poor results if your chosen tuner is not at home on them. Ditching the AFM's (put in gutted VL units if stock appearance is important) is something that could be worthwhile in the long run depending on your targets and future goals.
Replacing the injectors may end up being worth the cash as I have seen a decent set of ID's or similar make a very drivable car out of previous pig(s) so it can be worth the $$ to replace them.
All up it comes down to how much you want to spend and how much power you are aiming to make.
Edited by baron_von_bootsector
SAU automagically replaces "cops" with cops???
  • Like 1
Yuh, Sard 700cc are dinosaur grade tech and modern Bosch based (or similar) injectors will work much nicer.  Impedance choice is somewhat easy.  Just use high impedance injectors and remove any resistor box that may be between the ECU and the injector loom.
The PowerFC really is capable of running your engine well enough if it is tuned properly.  Both in terms of outright power and road manners.  Sure, newer ECUs with more blah-de-blah inside will do an even better job, but you are fairly well into the area of diminishing returns with respect to how big those improvements are.  I wouldn't replace the ECU unless a decent tuner tells you that it simply isn't capable of giving you some function that you're after, or simply can't give you the quality result you're after.  That last point should refer you back to my previous sentence about diminishing returns.  It is unlikely that a tuner who knows how to set it up properly would tell you that unless they wanted to sell you another ECU!
Yeah I don't really want to get into the tuna thing.  Perth is a hopeless case when it comes to such discussions and the nonsense that gets talked about them does my head in (EG He is brilliant but doesn't answer his phone, only works for friends of friends, etc etc etc).
Anyway the problem with the current setup broadly comes down to niceness, logging and the following on every full noise gear change.
This sort of thing for injectors?
http://www.ebay.com.au/itm/fit-Nissan-Skyline-rb26dett-r33-r34-r32-Bosch-750cc-fuel-injectors-GTR-turbo-/201948838193?hash=item2f0516b931:g:D2IAAOSwB09YMPwG
Or is there somewhere else recommended?
Or do you/can you use an RB20 harness (My existing one is obviously pretty old and may not enjoy being messed with)
Edited by djr81
I see no issues with this picture. Sorry I can't be of any more assistance.
Yup, something like that.  But lookup Scotty from on here (Scotty's customs) to support a local.
Let's put it this way.  The RB20 and the RB26 do not use the same injector harness.  The RB20 ran high impedance injectors.  The RB26 ran low.  So the 26 had the resistor pack.  But the presence of the resistor pack tells you that the 26 ECU expects to see high impedance injectors.....the same as all the other Nissan ECUs of the time.  The difference between the 26 and 20 ECUs was actually bugger all.  More or less the same thing, just with the extra bits for 2x AFMs and such.
So PowerFCs are also the same.  They expect high impedance injectors.  Put high impedance injectors into the 26's fuel rail and you have to bypass the resistor box.  You can buy patch harnesses that replace the resistor easily enough.
There is no substitute for a decent tuner. People have made huge power with PFC, successfully dragged and circuit raced with them.  Sure if you were buying an ECU today there would be many better but a good tuner can get good results with a PFC - 500hp should be a piece of cake. Of course that assumes that everything is installed correctly. And you can get datalogit for PFC.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
