Idling then dies
IDLING ISSUES!!
Hey guys, I have a 1994 r33 gts25t auto (rb25det). On cold start I have to use the throttle to get it going and use the throttle to warm it up. When it's warm 5 mins later I release the throttle for it to idle and it slowly dies. Start it back up with no throttle and she runs mint for 30 seconds then it dies again. Within that 30 seconds I can touch the throttle and it will idle until 30 seconds is up then again....it dies. Try to blip the throttle after that 30 seconds and it dies again. I have...
Resoldered the afm and fitted another working afm.
Replaced aac valve.
Set tps to .45V.
Fitted another relay for a constant 12V to the fuel pump.
Opened up cold start valve and it was clean as.
Vacuum tested the intake and no leaks occurred.
Removed and cleaned throttle body right up.
Checked ecu for codes, nothing appeared.
Replaced temp sensor.
BCPR6ES gapped to .8.
Cleaned cam angle sensor.
Checked ecu for any burn or corroded connections inside.
Anyone please help me if they have had this issue, I've never heard of it happening.
https://www.sau.com.au/forums/topic/471382-idling-then-dies/
I pressurized the inlet system for any vacuum leaks and there aren't any, visually looked at all the lines also.
While driving I have to double foot it so it won't die at lower speeds and stopping. (Just the same idling issue) I feel like something is drawing the current iswell because it won't start after a couple days of not starting. It slow cranks when that happens but then some times it's starts up ? it is charging, I checked with a multi meter. Maybe need to do another test of some sort?
Pressure test the fuel system. FPRs rarely fail but good to check. have you replaced the fuel filter in the engine bay? Long shot if you can swap out the ecu with someone just to eliminate that as a problem.
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
