Guest Robo's
see my sig for times.  (beofre cooler and flywheel)
I looking for 12s (12.9) as I just fitted a lightweight flywheel which are reputedly good for 0.4 - 0.5.
Also bolted in front mount cooler which should add a touch.
PowerFC coming soon.
Definent 12s
Join the exclusive 12 second stock turboed, no nos, street rubber club.
I doubt whether the flywheel would help you that much. So if i fitted the flywheel i would be running mid 12's, i doubt it, but still if i picked up 0.1 i'd be happy.
I picked up over 3/10's and 4mph with the intercooler.
Yeah I agree thats why next time when I'm not wheel spinning so bad I will get the 120mph. 120MPH should put any car deep into the 11's even 10's.
You can watch the video of it the car lights it into 3rd gear
BR,
JH
Alot of mods there, i wouldnt be happy with anything short of 120mph.
I still cant beleive you got a 12 with standard turbo, are you SURE its still the standard turbo? I spose with that 60ft time and a perfect drive its not impossible
Here's my response from boostcruising:
I'm in exactly the same situation as you so here's my advice based on waaay too many hours of research:
- 2530 will make plenty of power all the way to redline. You've picked the perfect turbo so don't worry about that.
- I'm also hesitant to upgrade my injectors without really needing to. You've got the cost of injectors ($300-400), management ($1500-2000), AFM ($300) plus labour. Just make the most out of what you've got and be happy with it.
- Get the car on a dyno and just run the most boost you can before totally maxing out the injectors. I'm hoping to run 1.2-1.3bar max.
- Put some 225/50/16 semi-slicks on your stock rims (something like Falken RT215s which are fairly cheap) and drop the air pressure to 20psi.
- Swap your coilovers for a standard set of springs and shocks for the weekend.
- Install 'pineapples' (subframe bushes) to minimise axle tramp.
- Lightened flywheel will definately be an advantage. I'm looking round for a twin plate clutch which come with lightened flywheel, not as light as aftermarket but better than stock.
That's exactly what i'm planning for my car and hopefully with some practice and luck i can run a 12.7-12.8 (or maybe slightly better with my weight advantage over the r32).
Im telling ya 20psi in ya tyres wont do anything noticable get them squashed run 8psi do a massive burnout and then launch and tell me if it made no difference.
BR
JH
WSID was designed to be one of the quickest, legal drag racing tracks in the world. There's alot of sneaky development that went into building the track, that all fits within acceptable rules. Little things like the maximum amount of downhill gradient allowed, track surface and base, as well as the U shaped design to mimimise headwind etc.
Thanks,
Scott
Hi mate,
with regards to spinning on the rims Im not sure I am no way a tyre expert I just tried the 20psi then 15 but found huge difference with sub 10psi in them.
Yes doing 12's on standard turbo does amaze me a bit. ?? Have you guys got a dyno print out ? The guys pulling the high 12s ons tandard turbos?
BR,
JH
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
