New to SAU and New to turbo
Hey everyone,
I have owned my R32 for 5 months and only truly had it running well for a few weeks. Its a RB20 with RB25 turbo.
Also this is my first turbo engine I've ever owned and worked on. So far I've learned a lot. First week the turbo started to whistle. After removing the turbo I found the fins broke.
Next week the ignition control module gave out and I went and did the z32 conversion also took the opportunity to change the ignition coils, plugs and pigtails
This time the turbo went out again. I heard it something broke and lost all boost. The shaft itself broke clean. I have read that these ceramic breaks and its common. But I am wondering if the shaft breaking is common as well. Right before it broke, there was no heavy boosting. I was pushing about 5psi every shift just letting it whistle...
Next turbo going in is the HKS GARRETT GT2530. I would like to make sure that the shaft breaking is a common problem or was it because of lack of oil. When I removed the oil bolt on the turbo the fluid looked consistent. Nothing alarming to where it looked dry.
Any tips appreciated! I also attached a photo of the broken shaft.
https://www.sau.com.au/forums/topic/471641-new-to-sau-and-new-to-turbo/
I've blown a stock 21U in that exact fashion and found the oil feed to the turbo blocked, so that's a good thing to check. If you don't already have one, put a new braided line there to ensure it's clean and crank the car to make sure there's oil flowing.
While you're only running 5psi you have no idea how hard it might have been pushed in it's past life and it could have been waiting to happen, they are sadly not well known for their strength.. :(
2 hours ago, GeeDog said:
I've also broken the shaft in a track car, and we are pretty sure it was from oil starvation. It might be worth talking to Tao at Hypergear in Melbourne about a rebuild & highflow of your turbo, as an option to a HKS.
+1
A rebuild and high flow also comes with a braided oil feed as standard ;)
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
