Some people run N1 pumps with no problems. There were a dodgy batch of knockoffs around for a while. Maybe as above get some billet gears and make sure you loctite the screws when you put it together.
Tomei would be great but they are $$$
Bigger hi-volume pump should be matched with a larger capacity sump if budget allows, a tomei/nitto pump will be capable of higher rpm and thus will be able to move a higher volume of oil.  Larger returns and crankcase venting also good 'while you're here' mods.
Some good info here;
https://www.facebook.com/pg/Tarmac-Solutions-Pty-Ltd-189006661230825/photos/?tab=album&album_id=399827453482077
Edited by JGTC
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
