45 minutes ago, adam wicks said:
Also this has 2 spots for vac hoses do they both go to the manifold ?
And this is a solenoid that is used to trigger (I think) the vacuum to the charcoal canister when the (factory) ECU determines that it is OK to do it.  So, no, both do not go to the manifold.  On the stocker, one would go to a vacuum source and the other snakes off towards the front of the car.
5 hours ago, adam wicks said:
Is it for vac?
Yes, but not in the way that you're thinking.  That pipe is visible there, and on the other side of the timing cover.  On the inlet side, it is connected to the plenum.  On the other side it is connected to the suction port of the charcoal canister.  It provides the suck that purges the canister (and fuel tank) into the engine.
The solenoid valve you posted earlier is also connected to both the plenum and the charcoal canister.  It is the switch that makes the valve on the charcoal canister open.  There's no flow in that line, just a vacuum signal.
All the plenum vacuum you could ever want is available off the many vac ports they added down the back end of yoru new one.
Did you decide to put this plenum on without making notes on how the original setup was plumbed up?
  • Like 1
I work shift work and every time I started pulling the standard stuff off I got called to work for 12 hour shifts so I lost track and that's been the problem ahha
On 8/30/2017 at 6:55 PM, adam wicks said:
It's not for gain it's perparing for top mount turbo setup coming soon
Ah yes, but I have a top mount neo and do not need this manifold :P
That said, you're in it, and it's on the car, so may as well finish it now.
  • Like 1
  • Haha 1
Sorry, but that makes no sense.  There is more than one way I can read your question and none of them make sense.
1. Are you talking about the small hose on the barb on the intercooler return pipe just before the blue silicon joiner?  If so, that is not stock, it has been put there by somebody else, so it could be for anything.  It could be connected to that boost controller we see behind the PS reservoir.  It could be for a boost gauge.
2. Are you talking about the boost controller in the background?  If you are, one side (the input side) must come from the turbo outlet or intercooler hot pipe.  The other side goes to the wastegate actuator.
That one (the barb, near the blue joiner) is stock on a R34 neo, it does indeed go to the power steering. It's used for speed sensitive power steering (somehow) and disconnecting it does result in some VERY heavy steering.. as well as a boost leak).
It runs from the PS to the charge pipe. It doesn't run to the plenum, so it'll go back to somewhere on your intercooler piping. If this doesn't exist, well you can block the hose if you like heavy steering all the time, or get a fitting put on your charge pipes.
  • Like 1
Yes the barb is factory on the 34s thank you glad you could understand haha
Thanks so don't delete it just put it back into the cooler pipes no problem thanks for explaining it to I wasn't sure what it was for
Nuh it's a power steering air control valve, it's only for bumping up idle when you turn the steering wheel. Mine's removed when I got a replacement pressure hose made up
Just block up the fitting that goes back to the plenum and the IC pipe
  • Like 1
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
