Help, What coilovers go on a 2000 r34 gt sedan?
Hey guys, im pretty new to the skyline crew, and to the SAU community ive just bought myself a 2000, r34 sedan N/A and i was wondering what coilovers would fit? I've done some research but not 100% percernt sure what will fit.
Help would be much appreciated :) Located QLD
Edited by Billy 34
All of them. Most popular atm seems to be MCA, could also go HSD/BC/Tein/ebayspec/pedders/bilsteins depends on your budget and application
Edit: MCA is from QLD, support the locals ;)
Have a look at your rear suspension. There are 2 types. Eyelet and fork. It should be pretty obvious what you have. (I'd be betting eyelet) in which case you would need R33 coilovers or ones that are specifically for the 25gt variant.
Yeah bro, but would they just be r34 gt sedans?
Yep, their the same as mine. R33 coilovers should bolt straight in. There mine be some differences on different coilovers. Just know to get to the top of the rears you need to remove the backseat. (At least on the coupe)
i have a sedan bro, would they be any 33 ones, because i heard i need 33 gtr coils to fit?
Edited by Billy 34
Just now, GTofuS-T said:
No, the GTR rear coilovers are the fork style same as R34 GT-T, the GT is eyelet as above which woudl be the same as R33 GTS-T (and GTS I would assume?)
alright mad, ill scout some out tonight, not sure if i should get someone to change them for me or if i should give it ago haha :) cheers for your help brother
3 hours ago, vxsr33 said:
Give it a go yourself and save your money. its very easy, will probs take about 3 or 4 hours if you haven't done it before.
I'll give it all, heard the spring are dangerous and can fling out if they aren't pulled out correctly
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
