  • Replies 82
Had a good time
First run on a 1/4 ever i got [email protected] 2.188 60ft!
Next few runs were bad 60ft times.. out of 8 runs only 2 were less than 2.3, not sure what i changed but it definately affected my 60ft. Worst 60ft was 2.508 which i got twice! Best et was 4th run i think, 13.878 @ 102.93 2.206 60ft. thought i had 13.7 :)
Good nite though, cant wait to give it another go, i was really suprised to see how much changing little things affects your times, i did a burnout and got a worse 60ft than i did before, upping boost made 60ft times worse, but more mid/top end. Guess the more playing around the better u get
I found an error on one of my time slips too, on the 13.9 run the other person got 14.599 and for margin it says 1.088 ?
2.998!
O M G ...
Ha! call that a 60ft time?? I've had a 6.59 you pussies :wassup:
Tonight my best were 2.097,2.082 and 2.029 got no top end though best I could do was 13.8 at 100.27mph and 13.9 at 104....good enough to win 5 out of 8 runs though 2 of the losses went to a 10.9 at 130mph and a 14.09 at 126mph.
Got myself a rotary too + Holden ute and a commidor
Fairly average night topped off by collecting a $150 fine ...89 in a 70 zone.
After cruising all the way home just under the limits I had a momentary lapse of attention.....at the end of the Centenary Hwy....of all places....it really pissed me off!!!
Nice to see you guys out there. knore seems to have got off to a good start :)
Addit: I got track slicks....but I got no squat
Nice to see you guys out there. knore seems to have got off to a good start  :D
Shyyt! I was lucky then, i was following MJ and the rest of the lines when i realised my bonnet was popped! so i pulled over closed it and made haste to catch up :Oops:
Hey matt, can u post up the details for that 14 flat run i did, i didnt end up collecting the time slip cause i went through the pile like 3 times and couldnt find it
Im still trying to figure out why nearly all my 60ft's were 2.4+, I wasnt getting wheelspin, the only thing i can think of on my 2 13 runs were i got to stage first and wasnt rushed, so i must have got the stall just right. I tried using the handbrake on one, but it broke traction when i released which gave me a 14.5
After last nite i kinda want a stall converter, cos i just couldnt stall high enough, on one of my races i was against a 180sx, he got a 12.88 with a 1.766 60ft!!
If we could get a 1.766 then imagine the ET ;)
Is your car an auto Knore?
Yes, thats where the problem is
Everything else is fine, i just cant load up enough power at the start
Im thinking about going on a full tank next time, so i can stall higher without the wheels spinning. Whats affecting my 60ft is that few seconds on 2.5L power (or lack of i should say) before the turbo hits. If i can cut that out, 2.0 60ft should be obtainable and good for some mid 13s
I tried stalling higher, but the wheels started spinning on the starting line :Oops:
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
