Oversize valves?
Yep, 1mm.
Apparently the valve stems were worn and getting thin. So, kind of lucky/unlucky I pulled the engine down.
Lucky, because I wouldn't want to drop a valve into a piston.
Unlucky, because the knock I though was bearings, was a loose cam gear.
I see twin manifolds, I sad now [emoji20]
Already set up for twins.
Means I can drop it in, start it up and drive.
Rather than having to get exhaust modded and tune again.
Also, they're big twins [emoji4]
If that helps
If that helps
Even more sad now, will be big lags
They're not too bad(considering)
I'd equate the lag to a 6766 on a 26
And similat power output on 98.
The 30 bottom end certainly helps.
I still have a 6boost single manifold.
If I keep the car, will probably go single again one day.
Oh, I also cant afford the turbo and head work I'd like to really take advantage of a single.
And cant beat the stock look of direct replacement twins.
Gold:
Had a hole in the rear dump pipe welded, which meant i could finally fit it all up.
Installed both turbos, dumps, merge pipe, turbo oil drain hoses, oil feeds.
Front dump pipe was fouling the rear turbo(swapped the hip dumps that were originally on these turbos to the nismo turbos in the white car as it will see track use).
'Clearenced' it with a hammer.
Came up ok.
Can see in the pics how close it still is.
These turbos are massive.
I finally put factory rear housing heat shields on, and they touch and bend on the rear housing due to the size.
Anyway, keep those questions coming.
XXX I cant afford a big single and decent gear box yet, so staying twins for now. One day XXX
Gold:
Fit the IAC assembly.
Placed on harmonic balancer.
Fit alternator belt
Fit oil filter
Fit drivers engine mount
Fit rear head drain.
Not much left now.
Have to tighten the balancer and try and get a joiner for the rear head drain hose.
  • Like 1
11 hours ago, luke gtr said:
Gold:
Fit alternator belt
Fit oil filter
Not much left now.
Celebratory skid? It's standard SAU practice
Gold:
Put the T in the head drain and rear turbo hose.
Hunting around for an option that would fit due to the different sizes in the hoses.
19mm brass T was about $65.
Went to bunnings and found pretty much what I needed for $6.
Required a little modding, but got there in the end.
Wrapped in heat wrap due to the proximity to the turbo dump pipes.
Being street driven, should be ok.
Also, tightened the harmonic balancer. 20181009_170559.jpg20181009_174119.jpg20181009_174551.jpg20181009_174600.jpg
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
