Hi guys
Trying to do some research but was unable to really find anything on the R33 GTR 320km dash clusters. Were they a factory option or are they an aftermarket only? I thought they came in all Vspecs but after looking online and doing some research I was completely wrong.
Any information would be awesome
Edited by Dion_M
https://www.sau.com.au/forums/topic/472298-nismo-320-cluster/
